#include <BaseNode.hh>
virtual bool AttachChild (NodePtr _child)=0
virtual NodeStorePtr Children () const =0
virtual bool DetachChild (NodePtr _child)=0
virtual math::Pose3d RawLocalPose () const =0
virtual void SetLocalScaleImpl (const math::Vector3d &_scale)=0
virtual void SetRawLocalPose (const math::Pose3d &_pose)=0
bool initialLocalPoseSet = false
◆ BaseNode()
BaseNode ( )
◆ ~BaseNode()
~BaseNode ( )
◆ AddChild()
void AddChild ( NodePtr  _child)
[in]_childChild node to be added
Implements Node.
◆ AttachChild()
protectedpure virtual
Implemented in Ogre2Node, and OgreNode.
Referenced by BaseNode< OgreObject >::AddChild().
◆ ChildById()
NodePtr ChildById ( unsigned int  _id) const
[in]_idID of the desired node
The specified node
Implements Node.
◆ ChildByIndex()
NodePtr ChildByIndex ( unsigned int  _index) const
The specified node
Implements Node.
Referenced by BaseNode< OgreObject >::PreRenderChildren().
◆ ChildByName()
NodePtr ChildByName ( const std::string &  _name) const
The specified node
Implements Node.
◆ ChildCount()
unsigned int ChildCount ( ) const
The number of child nodes
Implements Node.
Referenced by BaseNode< OgreObject >::PreRenderChildren(), and BaseNode< OgreObject >::RemoveChildren().
◆ Children()
◆ DetachChild()
◆ HasChild()
bool HasChild ( ConstNodePtr  _child) const
True if given node is an attached child
Implements Node.
◆ HasChildId()
bool HasChildId ( unsigned int  _id) const
True if node with given ID is an attached child
Implements Node.
◆ HasChildName()
bool HasChildName ( const std::string &  _name) const
True if node with given name is an attached child
Implements Node.
◆ HasUserData()
bool HasUserData ( const std::string &  _key) const
[in]_keyUnique key
True if node has custom data with the specified key
Implements Node.
◆ InheritScale()
overridepure virtual
Implements Node.
Referenced by BaseNode< OgreObject >::SetWorldScale(), and BaseNode< OgreObject >::WorldScale().
◆ InitialLocalPose()
math::Pose3d InitialLocalPose ( ) const
The initial local pose
Implements Node.
◆ LocalPose()
◆ LocalPosition()
math::Vector3d LocalPosition ( ) const
The local position
Implements Node.
◆ LocalRotation()
math::Quaterniond LocalRotation ( ) const
The local rotation
Implements Node.
◆ LocalScale()
The local scale
Implements Node.
Implemented in Ogre2Node, OgreNode, BaseAxisVisual< OgreVisual >, and BaseAxisVisual< Ogre2Visual >.
Referenced by BaseNode< OgreObject >::Scale(), and BaseNode< OgreObject >::WorldScale().
◆ Origin()
math::Vector3d Origin ( ) const
The position of the origin
Implements Node.
◆ Parent()
◆ PreRenderChildren()
void PreRenderChildren ( )
◆ RawLocalPose()
Referenced by BaseNode< OgreObject >::LocalPose().
◆ RemoveChild()
NodePtr RemoveChild ( NodePtr  _child)
[in]_childChild node to be removed
The removed child node
Implements Node.
◆ RemoveChildById()
NodePtr RemoveChildById ( unsigned int  _id)
[in]_idID of the child node to be removed
Implements Node.
◆ RemoveChildByIndex()
NodePtr RemoveChildByIndex ( unsigned int  _index)
[in]_indexIndex of the child node to be removed
Implements Node.
Referenced by BaseNode< OgreObject >::RemoveChildren().
◆ RemoveChildByName()
NodePtr RemoveChildByName ( const std::string &  _name)
[in]_nameName of the child node to be removed
Implements Node.
◆ RemoveChildren()
void RemoveChildren ( )
Implements Node.
◆ RemoveParent()
void RemoveParent ( )
Implements Node.
Referenced by BaseNode< OgreObject >::Destroy().
◆ Scale() [1/3]
void Scale ( double  _scale)
[in]_scaleScalar to alter the current scale
Implements Node.
Referenced by BaseNode< OgreObject >::Scale().
◆ Scale() [2/3]
void Scale ( double  _x,
double  _y,
double  _z
[in]_xScalar to alter the current x-coordinate scale
[in]_yScalar to alter the current y-coordinate scale
[in]_zScalar to alter the current z-coordinate scale
Implements Node.
◆ Scale() [3/3]
void Scale ( const math::Vector3d &  _scale)
[in]_scaleScalars to alter the current scale
Implements Node.
◆ SetLocalPose()
void SetLocalPose ( const math::Pose3d &  _pose)
◆ SetLocalPosition() [1/2]
void SetLocalPosition ( double  _x,
double  _y,
double  _z
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
Implements Node.
Referenced by BaseNode< OgreObject >::SetLocalPosition().
◆ SetLocalPosition() [2/2]
void SetLocalPosition ( const math::Vector3d &  _position)
[in]_positionNew local position
Implements Node.
◆ SetLocalRotation() [1/3]
void SetLocalRotation ( double  _r,
double  _p,
double  _y
[in]_rroll
[in]_ppitch
[in]_yyaw
Implements Node.
Referenced by BaseNode< OgreObject >::SetLocalRotation().
◆ SetLocalRotation() [2/3]
void SetLocalRotation ( double  _w,
double  _x,
double  _y,
double  _z
[in]_wW-coordinate
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
Implements Node.
◆ SetLocalRotation() [3/3]
void SetLocalRotation ( const math::Quaterniond &  _rotation)
[in]_rotationNew local rotation
Implements Node.
◆ SetLocalScale() [1/3]
void SetLocalScale ( double  _scale)
[in]_scaleNew local scale
Implements Node.
Referenced by BaseNode< OgreObject >::Scale(), BaseNode< OgreObject >::SetLocalScale(), and BaseNode< OgreObject >::SetWorldScale().
◆ SetLocalScale() [2/3]
void SetLocalScale ( double  _x,
double  _y,
double  _z
[in]_xNew x-coordinate scale
[in]_yNew y-coordinate scale
[in]_zNew z-coordinate scale
Implements Node.
◆ SetLocalScale() [3/3]
Implements Node.
Reimplemented in BaseAxisVisual< OgreVisual >, and BaseAxisVisual< Ogre2Visual >.
◆ SetLocalScaleImpl()
Referenced by BaseNode< OgreObject >::SetLocalScale().
◆ SetOrigin() [1/2]
void SetOrigin ( double  _x,
double  _y,
double  _z
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
Implements Node.
Referenced by BaseNode< OgreObject >::SetOrigin().
◆ SetOrigin() [2/2]
void SetOrigin ( const math::Vector3d &  _origin)
[in]_originNew origin position
Implements Node.
◆ SetRawLocalPose()
virtual void SetRawLocalPose ( const math::Pose3d &  _pose)
Referenced by BaseNode< OgreObject >::SetLocalPose().
◆ SetUserData()
void SetUserData ( const std::string &  _key,
Variant  _value
[in]_keyUnique key
[in]_valueValue in any type
Implements Node.
◆ SetWorldPose()
void SetWorldPose ( const math::Pose3d &  _pose)
Set the world pose.
[in]_poseNew world pose
Implements Node.
Referenced by BaseNode< OgreObject >::SetWorldPosition(), and BaseNode< OgreObject >::SetWorldRotation().
◆ SetWorldPosition() [1/2]
void SetWorldPosition ( double  _x,
double  _y,
double  _z
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
Implements Node.
Referenced by BaseNode< OgreObject >::SetWorldPosition().
◆ SetWorldPosition() [2/2]
void SetWorldPosition ( const math::Vector3d &  _position)
[in]_positionNew world position
Implements Node.
◆ SetWorldRotation() [1/3]
void SetWorldRotation ( double  _r,
double  _p,
double  _y
[in]_rroll
[in]_ppitch
[in]_yyaw
Implements Node.
Referenced by BaseNode< OgreObject >::SetWorldRotation().
◆ SetWorldRotation() [2/3]
void SetWorldRotation ( double  _w,
double  _x,
double  _y,
double  _z
[in]_wW-coordinate
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
Implements Node.
◆ SetWorldRotation() [3/3]
void SetWorldRotation ( const math::Quaterniond &  _rotation)
[in]_rotationNew world rotation
Implements Node.
◆ SetWorldScale() [1/3]
void SetWorldScale ( double  _scale)
[in]_scaleNew world scale
Implements Node.
Referenced by BaseNode< OgreObject >::SetWorldScale().
◆ SetWorldScale() [2/3]
void SetWorldScale ( double  _x,
double  _y,
double  _z
Implements Node.
◆ SetWorldScale() [3/3]
void SetWorldScale ( const math::Vector3d &  _scale)
Implements Node.
◆ UserData()
Variant UserData ( const std::string &  _key) const
[in]_keyUnique key
Value in any type. If _key does not exist for the node, an empty variant is returned (i.e., no data).
Implements Node.
◆ WorldPose()
◆ WorldPosition()
math::Vector3d WorldPosition ( ) const
The world position
Implements Node.
◆ WorldRotation()
math::Quaterniond WorldRotation ( ) const
The world rotation
Implements Node.
◆ WorldScale()
math::Vector3d WorldScale ( ) const
The world scale
Implements Node.
◆ WorldToLocal()
math::Pose3d WorldToLocal ( const math::Pose3d &  _pose) const
[in]_poseWorld pose to be converted
Implements Node.
Referenced by BaseNode< OgreObject >::SetWorldPose().
◆ initialLocalPose
Initial value:
Referenced by BaseNode< OgreObject >::InitialLocalPose(), and BaseNode< OgreObject >::SetLocalPose().
◆ initialLocalPoseSet
◆ origin
◆ userData
