#include <OgreJointVisual.hh>
virtual ~OgreJointVisual ()
- Public Member Functions inherited from BaseJointVisual< OgreVisual >
virtual ~BaseJointVisual ()
virtual ignition::math::Vector3d Axis () const override
 Get axis vector. More...
virtual ignition::math::Vector3d ParentAxis () const override
virtual void SetAxis (const ignition::math::Vector3d &_axis, bool _useParentFrame) override
virtual void SetParentAxis (const ignition::math::Vector3d &_axis, const std::string &_parentName, bool _useParentFrame) override
virtual bool UpdateAxis (const ignition::math::Vector3d &_axis, bool _useParentFrame) override
virtual bool UpdateParentAxis (const ignition::math::Vector3d &_axis, bool _useParentFrame) override
virtual ~JointVisual ()
virtual ~OgreVisual ()
virtual ~BaseVisual ()
virtual ~OgreNode ()
 OgreJointVisual ()
- Protected Member Functions inherited from BaseJointVisual< OgreVisual >
 BaseJointVisual ()
void CreateAxis ()
void CreateParentAxis ()
void ScaleToChild ()
void UpdateAxisImpl (ArrowVisualPtr _arrowVisual, const ignition::math::Vector3d &_axis, bool _useParentFrame)
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
- Protected Attributes inherited from BaseJointVisual< OgreVisual >
ArrowVisualPtr arrowVisual
ignition::math::Vector3d axis
AxisVisualPtr axisVisual
bool dirtyAxis
bool dirtyJointType
bool dirtyParentAxis
std::string jointParentName
 Joint parent name. More...
ignition::math::Vector3d parentAxis
 Parent axis vector. More...
bool parentAxisUseParentFrame
JointVisualPtr parentAxisVis
ignition::math::Vector3d scaleToChild
bool updateAxis
bool updateParentAxis
bool useParentFrame
uint32_t visibilityFlags
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreJointVisual()
OgreJointVisual ( )
◆ ~OgreJointVisual()
virtual ~OgreJointVisual ( )
