#include <ImuSensor.hh>
| ImuSensor () | |
| constructor More... | |
| virtual | ~ImuSensor () |
| destructor More... | |
| math::Vector3d | AngularVelocity () const |
| Get the angular velocity of the imu. More... | |
| math::Vector3d | Gravity () const |
| Get the gravity vector. More... | |
| bool | HasConnections () const |
| Check if there are any subscribers. More... | |
| math::Vector3d | LinearAcceleration () const |
| Get the linear acceleration of the imu. More... | |
| math::Quaterniond | Orientation () const |
| Get the orienation of the imu with respect to reference frame. More... | |
| bool | OrientationEnabled () const |
| Get whether or not orientation is enabled. More... | |
| math::Quaterniond | OrientationReference () const |
| Get the world orienation reference of the imu. More... | |
| void | SetAngularVelocity (const math::Vector3d &_angularVel) |
| Set the angular velocity of the imu. More... | |
| void | SetGravity (const math::Vector3d &_gravity) |
| Set the gravity vector. More... | |
| void | SetLinearAcceleration (const math::Vector3d &_linearAcc) |
| Set the linear acceleration of the imu. More... | |
| void | SetOrientationEnabled (bool _enabled) |
| Set whether to output orientation. Not all imu's generate orientation values as they use filters to produce orientation estimates. More... | |
| void | SetOrientationReference (const math::Quaterniond &_orient) |
| Set the orientation reference, i.e. initial imu orientation. Imu orientation data generated will be relative to this reference frame. More... | |
| void | SetWorldFrameOrientation (const math::Quaterniond &_rot, WorldFrameEnumType _relativeTo) |
| Specify the rotation offset of the coordinates of the World frame relative to a geo-referenced frame. More... | |
| void | SetWorldPose (const math::Pose3d _pose) |
| Set the world pose of the imu. More... | |
| math::Pose3d | WorldPose () const |
| Get the world pose of the imu. More... | |
| virtual | ~Sensor () |
| void | AddSequence (ignition::msgs::Header *_msg, const std::string &_seqKey="default") |
| Add a sequence number to an ignition::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More... | |
| FrameId. More... | |
| SensorId | Id () const |
| bool | IsActive () const |
| Get whether the sensor is enabled or not. More... | |
| Get name. More... | |
| ignition::math::Pose3d | Pose () const |
| Enable or disable the sensor. Disabled sensors will not generate or publish data unless Update is called with the '_force' argument set to true. More... | |
| void | SetPose (const ignition::math::Pose3d &_pose) |
| Sensor () | |
Imu Sensor Class.
An imu sensor that reports linear acceleration, angular velocity, and orientation
◆ ImuSensor()
| ImuSensor | ( | ) |
constructor
◆ ~ImuSensor()
virtual |
destructor
◆ AngularVelocity()
| math::Vector3d AngularVelocity | ( | ) | const |
- Returns
- Angular velocity of the imu in body frame, expressed in radians per second.
◆ Gravity()
| math::Vector3d Gravity | ( | ) | const |
- Returns
- Gravity vectory in meters per second squared.
◆ HasConnections()
| bool HasConnections | ( | ) | const |
- Returns
- True if there are subscribers, false otherwise
- Todo:
- (iche033) Make this function virtual on Garden
◆ Init()
overridevirtual |
◆ LinearAcceleration()
| math::Vector3d LinearAcceleration | ( | ) | const |
- Returns
- Linear acceleration of the imu in local frame, expressed in meters per second squared.
◆ Load() [1/2]
overridevirtual |
◆ Load() [2/2]
overridevirtual |
◆ Orientation()
| math::Quaterniond Orientation | ( | ) | const |
- Returns
- Orientation in reference frame. If orientation is not enabled, this will return the last computed orientation before orientation is disabled or identity Quaternion if orientation has never been enabled.
◆ OrientationEnabled()
| bool OrientationEnabled | ( | ) | const |
- Returns
- True if orientation is enabled, false otherwise.
◆ OrientationReference()
| math::Quaterniond OrientationReference | ( | ) | const |
- Returns
- Orientation reference in world frame
◆ SetAngularVelocity()
| void SetAngularVelocity | ( | const math::Vector3d & | _angularVel | ) |
[in] _angularVel Angular velocity of the imu in body frame expressed in radians per second
◆ SetGravity()
| void SetGravity | ( | const math::Vector3d & | _gravity | ) |
[in] _gravity gravity vector in meters per second squared.
◆ SetLinearAcceleration()
| void SetLinearAcceleration | ( | const math::Vector3d & | _linearAcc | ) |
[in] _linearAcc Linear accceleration of the imu in body frame expressed in meters per second squared.
◆ SetOrientationEnabled()
| void SetOrientationEnabled | ( | bool | _enabled | ) |
[in] _enabled True to publish orientation data, false to leave the message field empty.
◆ SetOrientationReference()
| void SetOrientationReference | ( | const math::Quaterniond & | _orient | ) |
[in] _orientation Reference orientation
◆ SetWorldFrameOrientation()
| void SetWorldFrameOrientation | ( | const math::Quaterniond & | _rot, |
| WorldFrameEnumType | _relativeTo | ||
[in] _rot rotation offset [in] _relativeTo world frame orientation, ENU by default
◆ SetWorldPose()
| void SetWorldPose | ( | const math::Pose3d | _pose | ) |
[in] _pose Pose in world frame
◆ Update()
overridevirtual |
[in] _now The current time
- Returns
Implements Sensor.
◆ WorldPose()
| math::Pose3d WorldPose | ( | ) | const |
- Returns
- Pose in world frame.
