#include <Lidar.hh>
| Lidar () | |
| constructor More... | |
| virtual | ~Lidar () |
| destructor More... | |
| ignition::math::Angle | AngleMax () const |
| Get the maximum angle. More... | |
| ignition::math::Angle | AngleMin () const |
| Get the minimum angle. More... | |
| double | AngleResolution () const |
| Get radians between each range. More... | |
| void | ApplyNoise () |
| Apply noise to the laser buffer, if noise has been configured. This should be called before PublishLidarScan if you want the scan data to contain noise. More... | |
| virtual ignition::common::ConnectionPtr | ConnectNewLidarFrame (std::function< void(const float *_scan, unsigned int _width, unsigned int _heighti, unsigned int _channels, const std::string &)> _subscriber) |
| Set a callback to be called when data is generated. More... | |
| virtual bool | CreateLidar () |
| Create Lidar sensor. More... | |
| int | Fiducial (const unsigned int _index) const |
| Get detected fiducial value for a ray. Warning: If you are accessing all the ray data in a loop it's possible that the Ray will update in the middle of your access loop. This means some data will come from one scan, and some from another scan. You can solve this problem by using SetActive(false) <your accessor loop> SetActive(true). More... | |
| bool | HasConnections () const |
| Check if there are any subscribers for sensor data. More... | |
| double | HorzFOV () const |
| Get the horizontal field of view of the laser sensor. More... | |
| virtual bool | IsActive () const |
| bool | IsHorizontal () const |
| Gets if sensor is horizontal. More... | |
| virtual bool | PublishLidarScan (const std::chrono::steady_clock::duration &_now) |
| Publish LaserScan message. More... | |
| double | Range (const int _index) const |
| Get detected range for a ray. Warning: If you are accessing all the ray data in a loop it's possible that the Ray will update in the middle of your access loop. This means some data will come from one scan, and some from another scan. You can solve this problem by using SetActive(false) <your accessor loop> SetActive(true). More... | |
| unsigned int | RangeCount () const |
| Get the range count. More... | |
| double | RangeCountRatio () const |
| Return the ratio of horizontal range count to vertical range count. More... | |
| double | RangeMax () const |
| Get the maximum range. More... | |
| double | RangeMin () const |
| Get the minimum range. More... | |
| double | RangeResolution () const |
| Get the range resolution If RangeResolution is 1, the number of simulated rays is equal to the number of returned range readings. If it's less than 1, fewer simulated rays than actual returned range readings are used, the results are interpolated from two nearest neighbors, and vice versa. More... | |
| void | Ranges (std::vector< double > &_ranges) const |
| Get all the ranges. More... | |
| unsigned int | RayCount () const |
| Get the ray count. More... | |
| double | RayCountRatio () const |
| Return the ratio of horizontal ray count to vertical ray count. More... | |
| double | Retro (const int _index) const |
| Get detected retro (intensity) value for a ray. Warning: If you are accessing all the ray data in a loop it's possible that the Ray will update in the middle of your access loop. This means some data will come from one scan, and some from another scan. You can solve this problem by using SetActive(false) <your accessor loop> SetActive(true). More... | |
| void | SetAngleMax (const double _angle) |
| Set the scan maximum angle. More... | |
| void | SetAngleMin (const double _angle) |
| Set the scan minimum angle. More... | |
| void | SetParent (const std::string &_parent) override |
| void | SetVerticalAngleMax (const double _angle) |
| Set the vertical scan line top angle. More... | |
| void | SetVerticalAngleMin (const double _angle) |
| Set the vertical scan bottom angle. More... | |
| double | VertFOV () const |
| Get the vertical field-of-view. More... | |
| ignition::math::Angle | VerticalAngleMax () const |
| Get the vertical scan line top angle. More... | |
| ignition::math::Angle | VerticalAngleMin () const |
| Get the vertical scan bottom angle. More... | |
| double | VerticalAngleResolution () const |
| Get the vertical angle in radians between each range. More... | |
| unsigned int | VerticalRangeCount () const |
| Get the vertical scan line count. More... | |
| unsigned int | VerticalRayCount () const |
| uint32_t | VisibilityMask () const |
| Get the visibility mask. More... | |
Public Member Functions inherited from RenderingSensor | |
| virtual | ~RenderingSensor () |
| bool | ManualSceneUpdate () const |
| Get whether the scene graph is updated manually. Defaults to false. More... | |
| void | Render () |
| Render update. This performs the actual render operation. More... | |
| rendering::ScenePtr | Scene () const |
| Get the rendering scene. More... | |
| void | SetManualSceneUpdate (bool _manual) |
| Set whether to update the scene graph manually. If set to true, it is expected that rendering::Scene::PreRender is called manually before calling Render() More... | |
| virtual void | SetScene (rendering::ScenePtr _scene) |
| Set the rendering scene. More... | |
| virtual | ~Sensor () |
| void | AddSequence (ignition::msgs::Header *_msg, const std::string &_seqKey="default") |
| Add a sequence number to an ignition::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More... | |
| FrameId. More... | |
| SensorId | Id () const |
| Get whether the sensor is enabled or not. More... | |
| Get name. More... | |
| ignition::math::Pose3d | Pose () const |
| Enable or disable the sensor. Disabled sensors will not generate or publish data unless Update is called with the '_force' argument set to true. More... | |
| void | SetPose (const ignition::math::Pose3d &_pose) |
Public Attributes | |
| bool | initialized = false |
| true if Load() has been called and was successful More... | |
| float * | laserBuffer = nullptr |
| Raw buffer of laser data. More... | |
| std::mutex | lidarMutex |
| Just a mutex for thread safety. More... | |
| virtual void | Fini () |
| Finalize the ray. More... | |
Protected Member Functions inherited from RenderingSensor | |
| RenderingSensor () | |
| void | AddSensor (rendering::SensorPtr _sensor) |
| Add a rendering::Sensor. Its render updates will be handled by this base class. More... | |
| Sensor () | |
This class creates laser scans using. It's measures the range from the origin of the center to points on the visual geometry in the scene.
It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ Lidar()
| Lidar | ( | ) |
constructor
◆ ~Lidar()
virtual |
destructor
◆ AngleMax()
| ignition::math::Angle AngleMax | ( | ) | const |
- Returns
- the maximum angle
◆ AngleMin()
| ignition::math::Angle AngleMin | ( | ) | const |
- Returns
- The minimum angle
◆ AngleResolution()
| double AngleResolution | ( | ) | const |
- Returns
- Return angle resolution
◆ ApplyNoise()
| void ApplyNoise | ( | ) |
◆ ConnectNewLidarFrame()
virtual |
[in] _callback This callback will be called every time the sensor generates data. The Update function will be blocked while the callbacks are executed.
- Remarks
- Do not block inside of the callback.
- Returns
- A connection pointer that must remain in scope. When the connection pointer falls out of scope, the connection is broken.
Reimplemented in GpuLidarSensor.
◆ CreateLidar()
virtual |
◆ Fiducial()
| int Fiducial | ( | const unsigned int | _index | ) | const |
[in] _index Index of specific ray
- Returns
- Fiducial value of ray
◆ Fini()
protectedvirtual |
Finalize the ray.
◆ HasConnections()
| bool HasConnections | ( | ) | const |
- Returns
- True if there are subscribers, false otherwise
- Todo:
- (iche033) Make this function virtual on Garden
◆ HorzFOV()
| double HorzFOV | ( | ) | const |
- Returns
- The horizontal field of view of the laser sensor.
◆ Init()
overridevirtual |
- Returns
- True on success
Reimplemented from Sensor.
◆ IsActive()
virtual |
◆ IsHorizontal()
| bool IsHorizontal | ( | ) | const |
- Returns
- True if horizontal, false if not
◆ Load() [1/2]
overridevirtual |
[in] _sdf SDF Sensor parameters.
- Returns
- true if loading was successful
◆ Load() [2/2]
overridevirtual |
- Returns
◆ PublishLidarScan()
virtual |
[in] _now The current time
- Returns
◆ Range()
| double Range | ( | const int | _index | ) | const |
- Returns
- Returns RangeMax for no detection.
◆ RangeCount()
| unsigned int RangeCount | ( | ) | const |
- Returns
- The number of ranges
◆ RangeCountRatio()
| double RangeCountRatio | ( | ) | const |
A ray count is the number of simulated rays. Whereas a range count is the total number of data points returned. When range count != ray count, then values are interpolated between rays.
◆ RangeMax()
| double RangeMax | ( | ) | const |
- Returns
- The maximum range
◆ RangeMin()
| double RangeMin | ( | ) | const |
- Returns
- The minimum range
◆ RangeResolution()
| double RangeResolution | ( | ) | const |
- Returns
- The Range Resolution
◆ Ranges()
| void Ranges | ( | std::vector< double > & | _ranges | ) | const |
Get all the ranges.
[out] _range A vector that will contain all the range data
◆ RayCount()
| unsigned int RayCount | ( | ) | const |
Get the ray count.
- Returns
- The number of rays
◆ RayCountRatio()
| double RayCountRatio | ( | ) | const |
◆ Retro()
| double Retro | ( | const int | _index | ) | const |
- Returns
- Intensity value of ray
◆ SetAngleMax()
| void SetAngleMax | ( | const double | _angle | ) |
[in] _angle The maximum angle
◆ SetAngleMin()
| void SetAngleMin | ( | const double | _angle | ) |
[in] _angle The minimum angle
◆ SetParent()
overridevirtual |
◆ SetVerticalAngleMax()
| void SetVerticalAngleMax | ( | const double | _angle | ) |
[in] _angle The Maximum angle of the scan block
◆ SetVerticalAngleMin()
| void SetVerticalAngleMin | ( | const double | _angle | ) |
[in] _angle The minimum angle of the scan block
◆ Update()
overridevirtual |
- Returns
Implements Sensor.
◆ VertFOV()
| double VertFOV | ( | ) | const |
- Returns
- Vertical field of view.
◆ VerticalAngleMax()
| ignition::math::Angle VerticalAngleMax | ( | ) | const |
- Returns
- The Maximum angle of the scan block
◆ VerticalAngleMin()
| ignition::math::Angle VerticalAngleMin | ( | ) | const |
- Returns
- The minimum angle of the scan block
◆ VerticalAngleResolution()
| double VerticalAngleResolution | ( | ) | const |
- Returns
- Resolution of the angle
◆ VerticalRangeCount()
| unsigned int VerticalRangeCount | ( | ) | const |
- Returns
- The number of scan lines vertically
◆ VerticalRayCount()
| unsigned int VerticalRayCount | ( | ) | const |
- Returns
◆ VisibilityMask()
| uint32_t VisibilityMask | ( | ) | const |
- Returns
- Visibility mask
◆ initialized
| bool initialized = false |
◆ laserBuffer
| float* laserBuffer = nullptr |
◆ lidarMutex
mutable |
