#include <Manager.hh>
| Manager () | |
| constructor More... | |
| virtual | ~Manager () |
| destructor More... | |
| void | AddPluginPaths (const std::string &_path) |
| Adds colon delimited paths sensor plugins may be. More... | |
| SensorId | AddSensor (std::unique_ptr< Sensor > _sensor) |
| Add a sensor for this manager to manage. More... | |
| SensorId | CreateSensor (const sdf::Sensor &_sdf) |
| Create a sensor from SDF without a known sensor type. More... | |
| SensorId | CreateSensor (sdf::ElementPtr _sdf) |
| template<typename SensorType , typename SdfType > | |
| SensorType * | CreateSensor (SdfType _sdf) |
| Create a sensor from an SDF ovject with a known sensor type. More... | |
| bool | Init () |
| Initialize the sensor library without rendering or physics. More... | |
| bool | Remove (const SensorId _id) |
| Remove a sensor by ID. More... | |
| void | RunOnce (const std::chrono::steady_clock::duration &_time, bool _force=false) |
| Run the sensor generation one step. More... | |
| Sensor * | Sensor (SensorId _id) |
| Get an instance of a loaded sensor by sensor id. More... | |
This class is responsible for loading and running sensors, and providing sensors with common environments to generat data from.
The primary interface through which to load a sensor is LoadSensor(). This takes an sdf element pointer that should be configured with everything the sensor will need. Custom sensors configuration must be in the <plugin> tag of the sdf::Element. The manager will dynamically load the sensor library and update it.
- Remarks
- This class is not thread safe.
◆ Manager()
| Manager | ( | ) |
constructor
◆ ~Manager()
virtual |
destructor
◆ AddPluginPaths()
| void AddPluginPaths | ( | const std::string & | _path | ) |
◆ AddSensor()
| SensorId AddSensor | ( | std::unique_ptr< Sensor > | _sensor | ) |
- See also
- Sensor()
[in] _sensor Pointer to the sensor
- Returns
- A sensor id that refers to the created sensor. NO_SENSOR is returned on error.
◆ CreateSensor() [1/3]
| SensorId CreateSensor | ( | const sdf::Sensor & | _sdf | ) |
- See also
- Sensor()
[in] _sdf SDF sensor DOM object
- Returns
- A sensor id that refers to the created sensor. NO_SENSOR is returned on erro.
- Deprecated:
- Sensor registration is deprecated, so it's necessary to provide the specific sensor type to create it. Use the templated
CreateSensorfunction.
◆ CreateSensor() [2/3]
| SensorId CreateSensor | ( | sdf::ElementPtr | _sdf | ) |
- See also
- Sensor()
[in] _sdf pointer to the sdf element
- Returns
- Deprecated:
◆ CreateSensor() [3/3]
inline |
- See also
- Sensor()
[in] _sdf An SDF element or DOM object.
- Template Parameters
SensorType Sensor type SdfType It may be an sdf::ElementPtrcontaining a sensor or ansdf::Sensor.
- Returns
- A pointer to the created sensor. Null returned on error. The Manager keeps ownership of the pointer's lifetime.
References Manager::AddSensor(), SensorFactory::CreateSensor(), std::endl(), std::move(), and ignition::sensors::NO_SENSOR.
◆ Init()
| bool Init | ( | ) |
- Returns
- True if successfully initialized, false if not
◆ Remove()
| bool Remove | ( | const SensorId | _id | ) |
[in] _sensorId ID of the sensor to remove
- Returns
- True if the sensor exists and removed.
◆ RunOnce()
| void RunOnce | ( | const std::chrono::steady_clock::duration & | _time, |
| bool | _force = false |
_time The current simulated time _force If true, all sensors are forced to update. Otherwise a sensor will update based on it's Hz rate.
◆ Sensor()
[in] _id Idenitifier of the sensor.
- Returns
- Pointer to the sensor, nullptr on error.
