| | NavSatSensor () |
| | Constructor. More...
| virtual | ~NavSatSensor () |
| | Destructor. More...
| double | Altitude () const |
| | Get NavSat altitude above sea level. More...
| bool | HasConnections () const |
| | Check if there are any subscribers. More...
| | Initialize values in the sensor. More...
| const math::Angle & | Latitude () const |
| | Get the latitude of the NavSat, wrapped between +/- 180 degrees. More...
| | Load the sensor based on data from an sdf::Sensor object. More...
| | Load the sensor with SDF parameters. More...
| const math::Angle & | Longitude () const |
| | Get the longitude of the NavSat, wrapped between +/- 180 degrees. More...
| void | SetAltitude (double _altitude) |
| | Set the altitude of the NavSat. More...
| void | SetLatitude (const math::Angle &_latitude) |
| | Set the latitude of the NavSat. More...
| void | SetLongitude (const math::Angle &_longitude) |
| | Set the longitude of the NavSat. More...
| void | SetPosition (const math::Angle &_latitude, const math::Angle &_longitude, double _altitude=0.0) |
| | Easy short hand for setting the position of the sensor. More...
| void | SetVelocity (const math::Vector3d &_vel) |
| | Set the velocity of the NavSat in ENU world frame. More...
| | Update the sensor and generate data. More...
| const math::Vector3d & | Velocity () const |
| | Get the velocity of the NavSat sensor in the ENU world frame. More...
| virtual | ~Sensor () |
| | destructor More...
| void | AddSequence (ignition::msgs::Header *_msg, const std::string &_seqKey="default") |
| | Add a sequence number to an ignition::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More...
| | Get flag state for enabling performance metrics publication. More...
| | FrameId. More...
| SensorId | Id () const |
| | Get the sensor's ID. More...
| bool | IsActive () const |
| | Get whether the sensor is enabled or not. More...
| | Get name. More...
| | Return the next time the sensor will generate data. More...
| | Get parent link of the sensor. More...
| ignition::math::Pose3d | Pose () const |
| | Get the current pose. More...
| | Publishes information about the performance of the sensor. This method is called by Update(). More...
| | Get the SDF used to load this sensor. More...
| | Enable or disable the sensor. Disabled sensors will not generate or publish data unless Update is called with the '_force' argument set to true. More...
| | Set flag to enable publishing performance metrics. More...
| | Set Frame ID of the sensor. More...
| | Set the parent of the sensor. More...
| void | SetPose (const ignition::math::Pose3d &_pose) |
| | Update the pose of the sensor. More...
| | Set topic where sensor data is published. More...
| | Set the update rate of the sensor. An update rate of zero means that the sensor is updated every cycle. It's zero by default. \detail Negative rates become zero. More...
| | Get topic where sensor data is published. More...
| | Update the sensor. More...
| | Get the update rate of the sensor. More...
NavSat Sensor Class.
A sensor that reports position and velocity readings over Ignition Transport using spherical coordinates (latitude / longitude).
By default, it publishes ignition::msgs::NavSat messages on the /.../navsat topic.
This sensor assumes the world is using the East-North-Up (ENU) frame.
