Ignition Sensors
DepthCameraSensor Class Reference
#include <DepthCameraSensor.hh>
 DepthCameraSensor ()
 constructor More...
virtual ~DepthCameraSensor ()
 destructor More...
ignition::common::ConnectionPtr ConnectImageCallback (std::function< void(const ignition::msgs::Image &)> _callback)
virtual rendering::DepthCameraPtr DepthCamera ()
virtual double FarClip () const
 Get image width. More...
 Get image height. More...
virtual bool Init () override
virtual double NearClip () const
void OnNewDepthFrame (const float *_scan, unsigned int _width, unsigned int _height, unsigned int, const std::string &)
 Depth data callback used to get the data from the sensor. More...
void OnNewRgbPointCloud (const float *_data, unsigned int _width, unsigned int _height, unsigned int, const std::string &)
 Point cloud data callback used to get the data from the sensor. More...
virtual void SetScene (ignition::rendering::ScenePtr _scene) override
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
SensorId Id () const
 Get the sensor's ID. More...
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
bool AdvertiseInfo ()
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates depth image from an ignition rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ DepthCameraSensor()
constructor
◆ ~DepthCameraSensor()
virtual ~DepthCameraSensor ( )
destructor
◆ ConnectImageCallback()
ignition::common::ConnectionPtr ConnectImageCallback ( std::function< void(const ignition::msgs::Image &)>  _callback)
Remarks
◆ DepthCamera()
virtual rendering::DepthCameraPtr DepthCamera ( )
[in]_nowThe current time
◆ FarClip()
virtual double FarClip ( ) const
Get image width.
width of the image
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ NearClip()
virtual double NearClip ( ) const
Get image height.
height of the image
◆ OnNewDepthFrame()
void OnNewDepthFrame ( const float *  _scan,
unsigned  int,
const std::string
[in]_scanpointer to the data from the sensor
[in]_widthwidth of the depth image
[in]_heightheight of the depth image
[in]_channelbytes used for the depth data
[in]_formatstring with the format
◆ OnNewRgbPointCloud()
void OnNewRgbPointCloud ( const float *  _data,
unsigned  int,
const std::string
[in]_datapointer to the data from the sensor
[in]_widthwidth of the point cloud image
[in]_heightheight of the point cloud image
[in]_channelbytes used for the point cloud data
◆ SetScene()
virtual void SetScene ( ignition::rendering::ScenePtr  _scene)
