Ignition Sensors
RgbdCameraSensor Class Reference
#include <RgbdCameraSensor.hh>
 RgbdCameraSensor ()
 constructor More...
virtual ~RgbdCameraSensor ()
 destructor More...
 Get image height. More...
 Get image width. More...
virtual bool Init () override
virtual void SetScene (ignition::rendering::ScenePtr _scene) override
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
ignition::common::ConnectionPtr ConnectImageCallback (std::function< void(const ignition::msgs::Image &)> _callback)
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
SensorId Id () const
 Get the sensor's ID. More...
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
bool AdvertiseInfo ()
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates a few types of sensor data from an ignition rendering scene:
  • RGB image (same as CameraSensor)
  • Depth image (same as DepthCamera)
  • (future / todo) Color point cloud The scene must be created in advance and given to Manager::Init(). It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ RgbdCameraSensor()
constructor
◆ ~RgbdCameraSensor()
virtual ~RgbdCameraSensor ( )
destructor
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ SetScene()
virtual void SetScene ( ignition::rendering::ScenePtr  _scene)
[in]_nowThe current time
true if the update was successful
