Ignition Sensors
SegmentationCameraSensor Class Reference
Segmentation camera sensor class. More...
#include <SegmentationCameraSensor.hh>
 SegmentationCameraSensor ()
 constructor More...
virtual ~SegmentationCameraSensor ()
 destructor More...
ignition::common::ConnectionPtr ConnectImageCallback (std::function< void(const ignition::msgs::Image &)> _callback)
 Get image height. More...
 Get image width. More...
virtual bool Init () override
void OnNewSegmentationFrame (const uint8_t *_data, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)
 Segmentation data callback used to get the data from the sensor. More...
rendering::SegmentationCameraPtr SegmentationCamera () const
 Get the rendering segmentation camera. More...
virtual void SetScene (ignition::rendering::ScenePtr _scene) override
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
SensorId Id () const
 Get the sensor's ID. More...
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
bool AdvertiseInfo ()
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates segmentation images from an ignition rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ SegmentationCameraSensor()
constructor
◆ ~SegmentationCameraSensor()
virtual ~SegmentationCameraSensor ( )
destructor
◆ ConnectImageCallback()
ignition::common::ConnectionPtr ConnectImageCallback ( std::function< void(const ignition::msgs::Image &)>  _callback)
Remarks
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ OnNewSegmentationFrame()
void OnNewSegmentationFrame ( const uint8_t *  _data,
const std::string _format
[in]_datapointer to the data from the sensor
[in]_widthwidth of the segmentation image
[in]_heightheight of the segmentation image
[in]_channelsnum of channels
[in]_formatstring with the format
◆ SegmentationCamera()
rendering::SegmentationCameraPtr SegmentationCamera ( ) const
Segmentation camera pointer
◆ SetScene()
virtual void SetScene ( ignition::rendering::ScenePtr  _scene)
[in]_nowThe current time
true if the update was successful
