Ignition Sensors
ThermalCameraSensor Class Reference
#include <ThermalCameraSensor.hh>
 ThermalCameraSensor ()
 constructor More...
virtual ~ThermalCameraSensor ()
 destructor More...
common::ConnectionPtr ConnectImageCallback (std::function< void(const msgs::Image &)> _callback)
 Get image height. More...
 Get image width. More...
virtual bool Init () override
void OnNewThermalFrame (const uint16_t *_scan, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)
 Thermal data callback used to get the data from the sensor. More...
virtual void SetAmbientTemperature (float _ambient)
 Set the ambient temperature of the environment. More...
virtual void SetAmbientTemperatureRange (float _range)
 Set the range of ambient temperature. More...
virtual void SetLinearResolution (float _resolution)
 Set the temperature linear resolution. The thermal image data returned will be temperature in kelvin / resolution. Typical values are 0.01 (10mK), 0.1 (100mK), or 0.04 to simulate 14 bit format. More...
virtual void SetMaxTemperature (float _max)
 Set the maximum temperature the sensor can detect. More...
virtual void SetMinTemperature (float _min)
 Set the minimum temperature the sensor can detect. More...
virtual void SetScene (ignition::rendering::ScenePtr _scene) override
virtual rendering::ThermalCameraPtr ThermalCamera ()
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
ignition::common::ConnectionPtr ConnectImageCallback (std::function< void(const ignition::msgs::Image &)> _callback)
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
SensorId Id () const
 Get the sensor's ID. More...
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
bool AdvertiseInfo ()
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates thermal image from an ignition rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ ThermalCameraSensor()
constructor
◆ ~ThermalCameraSensor()
virtual ~ThermalCameraSensor ( )
destructor
◆ ConnectImageCallback()
common::ConnectionPtr ConnectImageCallback ( std::function< void(const msgs::Image &)>  _callback)
Remarks
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ OnNewThermalFrame()
void OnNewThermalFrame ( const uint16_t *  _scan,
const std::string _format
[in]_scanpointer to the data from the sensor
[in]_widthwidth of the thermal image
[in]_heightheight of the thermal image
[in]_channelbytes used for the thermal data
[in]_formatstring with the format
◆ SetAmbientTemperature()
virtual void SetAmbientTemperature ( float  _ambient)
[in]_ambientAmbient temperature in kelvin
◆ SetAmbientTemperatureRange()
virtual void SetAmbientTemperatureRange ( float  _range)
[in]_rangeThe ambient temperature ranges from (ambient - range/2) to (ambient + range/2).
◆ SetLinearResolution()
virtual void SetLinearResolution ( float  _resolution)
[in]resolutionTemperature linear resolution
◆ SetMaxTemperature()
virtual void SetMaxTemperature ( float  _max)
[in]_maxMax temperature in kelvin
◆ SetMinTemperature()
virtual void SetMinTemperature ( float  _min)
[in]_minMin temperature in kelvin
◆ SetScene()
virtual void SetScene ( ignition::rendering::ScenePtr  _scene)
◆ ThermalCamera()
virtual rendering::ThermalCameraPtr ThermalCamera ( )
[in]_nowThe current time
