Ogre2.x implementation of the camera class. More...
#include <Ogre2Camera.hh>
virtual ~Ogre2Camera ()
virtual math::Color BackgroundColor () const
Ogre::Camera * OgreCamera () const
virtual void SetBackgroundColor (const math::Color &_color)
- Public Member Functions inherited from BaseCamera< Ogre2Sensor >
virtual ~BaseCamera ()
virtual ~Camera ()
 Sensor. More...
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
virtual ~Ogre2Node ()
 Ogre2Camera ()
 Create a render texture for the camera for offscreen rendering. More...
virtual void SetSelectionBuffer ()
 Create and set selection buffer object TODO(anyone) to be implemented. More...
- Protected Member Functions inherited from BaseCamera< Ogre2Sensor >
 BaseCamera ()
virtual RenderTargetPtr RenderTarget () const=0
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node. More...
math::Color backgroundColor
 Color of background. More...
 Pointer to ogre camera object. More...
Ogre2RenderTargetPtr renderTexture
 Pointer to render texture. More...
Ogre2SelectionBuffer * selectionBuffer = nullptr
 Selection buffer object for entity picking. More...
- Protected Attributes inherited from BaseCamera< Ogre2Sensor >
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2Camera()
Ogre2Camera ( )
◆ ~Ogre2Camera()
virtual ~Ogre2Camera ( )
◆ AntiAliasing()
Implements Camera.
◆ AspectRatio()
The camera's aspect ratio
Implements Camera.
◆ BackgroundColor()
◆ CreateRenderTexture()
◆ CreateRenderWindow()
Reimplemented from BaseCamera< Ogre2Sensor >.
Reimplemented from Ogre2Node.
◆ OgreCamera()
Ogre::Camera* OgreCamera ( ) const
◆ ProjectionMatrix()
Camera projection matrix
Implements Camera.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
◆ RenderTextureGLId()
Texture Id of type GLuint.
Implements Camera.
◆ SetAntiAliasing()
◆ SetAspectRatio()
image_height /
image_width
◆ SetBackgroundColor()
◆ SetFarClipPlane()
◆ SetHFOV()
◆ SetMaterial()
◆ SetNearClipPlane()
◆ SetSelectionBuffer()
virtual void SetSelectionBuffer ( )
◆ ViewMatrix()
Camera view matrix
Implements Camera.
◆ VisualAt()
virtual VisualPtr VisualAt ( const ignition::math::Vector2i &  _mousePos)
◆ backgroundColor
◆ ogreCamera
◆ renderTexture
◆ selectionBuffer
Ogre2SelectionBuffer* selectionBuffer = nullptr
