#include <BaseHeightmap.hh>
virtual const HeightmapDescriptor & Descriptor () override
 Get the immutable heightmap descriptor. More...
 Clone the geometry. More...
Public Attributes
HeightmapDescriptor descriptor
 Descriptor containing heightmap information. More...
 BaseHeightmap (const HeightmapDescriptor &_desc)
◆ BaseHeightmap()
BaseHeightmap ( const HeightmapDescriptor &  _desc)
explicitprotected
[in]_descDescriptor containing heightmap information.
◆ Descriptor()
const HeightmapDescriptor & Descriptor ( )
Descriptor with heightmap information.
Implements Heightmap.
void Destroy ( )
void PreRender ( )
Reimplemented in OgreHeightmap.
◆ descriptor
