#include <OgreArrowVisual.hh>
virtual ~OgreArrowVisual ()
- Public Member Functions inherited from BaseArrowVisual< OgreVisual >
virtual ~BaseArrowVisual ()
virtual ~ArrowVisual ()
virtual VisualPtr Head () const =0
virtual VisualPtr Rotation () const =0
virtual VisualPtr Shaft () const =0
virtual ~CompositeVisual ()
virtual ~OgreVisual ()
virtual ~BaseVisual ()
virtual ~OgreNode ()
 OgreArrowVisual ()
- Protected Member Functions inherited from BaseArrowVisual< OgreVisual >
 BaseArrowVisual ()
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
- Protected Attributes inherited from BaseArrowVisual< OgreVisual >
bool rotationVisible
 Flag to indicate whether arrow rotation is visible. More...
uint32_t visibilityFlags
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreArrowVisual()
OgreArrowVisual ( )
◆ ~OgreArrowVisual()
virtual ~OgreArrowVisual ( )
