#include <OgreVisual.hh>
virtual ~OgreVisual ()
virtual ~BaseVisual ()
virtual ~OgreNode ()
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
uint32_t visibilityFlags
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreVisual()
OgreVisual ( )
◆ ~OgreVisual()
virtual ~OgreVisual ( )
◆ AttachGeometry()
◆ BoundingBox()
virtual ignition::math::AxisAlignedBox BoundingBox ( ) const
The axis aligned bounding box
Implements Visual.
◆ DetachGeometry()
◆ Geometries()
◆ LocalBoundingBox()
virtual ignition::math::AxisAlignedBox LocalBoundingBox ( ) const
The local bounding box
Implements Visual.
◆ SetVisibilityFlags()
[in]_flagsVisibility flags
Reimplemented from BaseVisual< OgreNode >.
◆ SetVisible()
Reimplemented in BaseJointVisual< OgreVisual >, OgreLidarVisual, BaseArrowVisual< OgreVisual >, and BaseAxisVisual< OgreVisual >.
◆ SetWireframe()
◆ Wireframe()
Implements Visual.
◆ geometries
