BaseVisual< T > Class Template Referenceabstract
#include <BaseVisual.hh>
virtual ~BaseVisual ()
 BaseVisual ()
virtual bool AttachGeometry (GeometryPtr _geometry)=0
virtual bool DetachGeometry (GeometryPtr _geometry)=0
virtual GeometryStorePtr Geometries () const =0
uint32_t visibilityFlags = IGN_VISIBILITY_ALL
bool wireframe = false
◆ BaseVisual()
BaseVisual
◆ ~BaseVisual()
~BaseVisual
◆ AddGeometry()
void AddGeometry ( GeometryPtr  _geometry)
[in]_geometryGeometry to be added
Implements Visual.
◆ AddVisibilityFlags()
void AddVisibilityFlags ( uint32_t  _flags)
[in]_flagsVisibility flags
Implements Visual.
◆ AttachGeometry()
protectedpure virtual
Implemented in OgreVisual.
◆ BoundingBox()
ignition::math::AxisAlignedBox BoundingBox ( ) const
The axis aligned bounding box
Implements Visual.
◆ Clone()
VisualPtr Clone ( const std::string &  _name,
NodePtr  _newParent
) const
[in]_nameName of the cloned Visual. Set this to an empty string to auto-generate a unique name for the cloned visual.
[in]_newParentParent of the cloned Visual. Set to nullptr if the cloned visual should have no parent.
The visual. nullptr is returned if cloning failed.
Implements Visual.
void Destroy ( )
Reimplemented in BaseJointVisual< OgreVisual >, OgreLidarVisual, BaseLidarVisual< OgreVisual >, BaseArrowVisual< OgreVisual >, and BaseAxisVisual< OgreVisual >.
◆ DetachGeometry()
◆ Geometries()
◆ GeometryByIndex()
GeometryPtr GeometryByIndex ( unsigned int  _index) const
[in]_indexIndex of the desired geometry
The specified geometry
Implements Visual.
◆ GeometryCount()
unsigned int GeometryCount ( ) const
The number of geometries attached to this visual
Implements Visual.
◆ HasGeometry()
bool HasGeometry ( ConstGeometryPtr  _geometry) const
[in]_geometryGeometry in question
True if given node is attached to this visual
Implements Visual.
◆ LocalBoundingBox()
ignition::math::AxisAlignedBox LocalBoundingBox ( ) const
The local bounding box
Implements Visual.
◆ LocalPose()
math::Pose3d LocalPose ( ) const
Get the local pose.
The local pose
Implements Node.
Implements Visual.
Reimplemented in BaseParticleEmitter< OgreVisual >.
void PreRender ( )
Reimplemented in BaseGizmoVisual< OgreVisual >, OgreCOMVisual, OgreInertiaVisual, OgreLightVisual, BaseJointVisual< OgreVisual >, OgreLidarVisual, BaseCOMVisual< OgreVisual >, BaseParticleEmitter< OgreVisual >, BaseInertiaVisual< OgreVisual >, BaseLightVisual< OgreVisual >, and BaseLidarVisual< OgreVisual >.
◆ PreRenderChildren()
◆ PreRenderGeometries()
◆ RemoveGeometries()
void RemoveGeometries ( )
Implements Visual.
◆ RemoveGeometry()
GeometryPtr RemoveGeometry ( GeometryPtr  _geometry)
[in]_geometryGeometry to be removed
The removed geometry
Implements Visual.
◆ RemoveGeometryByIndex()
GeometryPtr RemoveGeometryByIndex ( unsigned int  _index)
[in]_indexIndex of the geometry to be removed
Implements Visual.
◆ RemoveVisibilityFlags()
void RemoveVisibilityFlags ( uint32_t  _flags)
Implements Visual.
◆ SetChildMaterial()
void SetChildMaterial ( MaterialPtr  _material,
bool  _unique = true
Implements Visual.
◆ SetGeometryMaterial()
void SetGeometryMaterial ( MaterialPtr  _material,
bool  _unique = true
Implements Visual.
◆ SetLocalPose()
void SetLocalPose ( const math::Pose3d &  _pose)
Set the local pose.
[in]_poseNew local pose
Implements Node.
◆ SetMaterial() [1/2]
bool  _unique = true
[in]_nameName of the material to be assigned
Implements Visual.
◆ SetMaterial() [2/2]
bool  _unique = true
Implements Visual.
Reimplemented in OgreInertiaVisual, OgreCOMVisual, and OgreLightVisual.
◆ SetVisibilityFlags()
void SetVisibilityFlags ( uint32_t  _flags)
Implements Visual.
Reimplemented in OgreVisual.
◆ SetVisible()
Implements Visual.
Reimplemented in BaseJointVisual< OgreVisual >, OgreLidarVisual, BaseArrowVisual< OgreVisual >, BaseAxisVisual< OgreVisual >, and OgreVisual.
◆ SetWireframe()
void SetWireframe ( bool  _show)
Implements Visual.
◆ VisibilityFlags()
uint32_t VisibilityFlags ( ) const
visibility flags
Implements Visual.
◆ Wireframe()
bool Wireframe ( ) const
Implements Visual.
◆ boundingBox
◆ material
◆ visibilityFlags
◆ wireframe
