Represents a arrow composite visual. More...
#include <ignition/rendering/ArrowVisual.hh>
| virtual | ~ArrowVisual () |
| Destructor. More... | |
| virtual VisualPtr | Head () const =0 |
| Get arrow-head visual. More... | |
| virtual VisualPtr | Rotation () const =0 |
| Get arrow-rotation visual. More... | |
| virtual VisualPtr | Shaft () const =0 |
| Get arrow-shaft visual. More... | |
| virtual void | ShowArrowHead (bool _b)=0 |
| set true to show the arrow head, false otherwise More... | |
| virtual void | ShowArrowRotation (bool _b)=0 |
| Set true to show the rotation of the arrow, false otherwise. More... | |
| virtual void | ShowArrowShaft (bool _b)=0 |
| set true to show the arrow shaft, false otherwise More... | |
Public Member Functions inherited from CompositeVisual | |
| virtual | ~CompositeVisual () |
Public Member Functions inherited from Visual | |
| virtual | ~Visual () |
| virtual void | AddGeometry (GeometryPtr _geometry)=0 |
| Add the given geometry to this visual. If the given node is already attached, no work will be done. More... | |
| virtual void | AddVisibilityFlags (uint32_t _flags)=0 |
| Add visibility flags. More... | |
| virtual ignition::math::AxisAlignedBox | BoundingBox () const =0 |
| Get the bounding box in world frame coordinates. More... | |
| virtual VisualPtr | Clone (const std::string &_name, NodePtr _newParent) const =0 |
| Clone the visual (and its children) with a new name. More... | |
| virtual GeometryPtr | GeometryByIndex (unsigned int _index) const =0 |
| Get geometry at given index. If no geometry exists at given index, NULL will be returned. More... | |
| virtual unsigned int | GeometryCount () const =0 |
| Get the number of geometries attached to this visual. More... | |
| virtual bool | HasGeometry (ConstGeometryPtr _geometry) const =0 |
| Determine if given geometry is attached to this visual. More... | |
| virtual ignition::math::AxisAlignedBox | LocalBoundingBox () const =0 |
| Get the local bounding box of the visual. More... | |
| Get the material assigned to attached visuals and geometries. More... | |
| virtual void | RemoveGeometries ()=0 |
| Remove all attached geometries from this visual. More... | |
| virtual GeometryPtr | RemoveGeometry (GeometryPtr _geometry)=0 |
| Remove the given geometry from this visual. If the given node is not a child of this visual, no work will be done. More... | |
| virtual GeometryPtr | RemoveGeometryByIndex (unsigned int _index)=0 |
| Remove the geometry at the given index from this visual. If the specified node is not attached this visual, no work will be done. More... | |
| virtual void | RemoveVisibilityFlags (uint32_t _flags)=0 |
| Remove visibility flags. More... | |
| virtual void | SetChildMaterial (MaterialPtr _material, bool _unique=true)=0 |
| Set the material for all attached visuals only. More... | |
| virtual void | SetGeometryMaterial (MaterialPtr _material, bool _unique=true)=0 |
| Set the material for all attached geometries only. More... | |
| Set the material for all attached visuals and geometries. The specified material will be retrieved from Scene::Material using the given material name. If no material is registered with the given name, no work will be done. More... | |
| Set the material for all attached visuals and geometries. More... | |
| virtual void | SetVisibilityFlags (uint32_t _flags)=0 |
| Set visibility flags. More... | |
| virtual void | SetVisible (bool _visible)=0 |
| Specify if this visual is visible. More... | |
| virtual void | SetWireframe (bool _show)=0 |
| Enable or disable wireframe. More... | |
| virtual uint32_t | VisibilityFlags () const =0 |
| Get visibility flags. More... | |
| virtual bool | Wireframe () const =0 |
| Get whether wireframe is enabled for this visual. More... | |
| virtual | ~Node () |
◆ ~ArrowVisual()
inlinevirtual |
References ArrowVisual::Head(), ArrowVisual::Rotation(), ArrowVisual::Shaft(), ArrowVisual::ShowArrowHead(), ArrowVisual::ShowArrowRotation(), and ArrowVisual::ShowArrowShaft().
◆ Head()
pure virtual |
- Returns
- The arrow-head visual
Implemented in BaseArrowVisual< T >, BaseArrowVisual< OgreVisual >, and BaseArrowVisual< Ogre2Visual >.
Referenced by ArrowVisual::~ArrowVisual().
◆ Rotation()
pure virtual |
- Returns
- The arrow-rotation visual
◆ Shaft()
pure virtual |
- Returns
- The arrow-shaft visual
◆ ShowArrowHead()
pure virtual |
[in] _b true to show the arrow head, false otherwise
Referenced by BaseAxisVisual< Ogre2Visual >::ShowAxisHead(), and ArrowVisual::~ArrowVisual().
◆ ShowArrowRotation()
pure virtual |
[in] _b True to show the arrow rotation.
◆ ShowArrowShaft()
pure virtual |
[in] _b true to show the arrow shaft, false otherwise
