BaseBoundingBoxCamera< T > Class Template Referenceabstract
#include <BaseBoundingBoxCamera.hh>
virtual ~BaseBoundingBoxCamera ()
virtual const std::vector< BoundingBox > & BoundingBoxData () const
 Get the BoundingBox data. More...
virtual ignition::common::ConnectionPtr ConnectNewBoundingBoxes (std::function< void(const std::vector< BoundingBox > &)> _subscriber)=0
 Connect to the new BoundingBox info. More...
virtual void DrawBoundingBox (unsigned char *_data, const math::Color &_color, const BoundingBox &_box) const =0
 Draw a bounding box on the given image. More...
virtual void SetBoundingBoxType (BoundingBoxType _type)
 Set BoundingBox Type (Visible / Full) More...
virtual BoundingBoxType Type () const
 Get the BoundingBox Type (Visible / Full) More...
- Public Member Functions inherited from BoundingBoxCamera
virtual ~BoundingBoxCamera ()
virtual ~Camera ()
virtual void Render ()=0
 Sensor. More...
 Set visibility mask. More...
 Get visibility mask. More...
virtual ~BaseCamera ()
 BaseCamera ()
std::vector< BoundingBox > boundingBoxes
 The bounding box data. More...
BoundingBoxType type = BoundingBoxType::BBT_FULLBOX2D
 The bounding box type. More...
 Anti-aliasing. More...
double aspect = 1.3333333
 Aspect ratio. More...
double farClip = 1000.0
NodePtr followNode
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
◆ BaseBoundingBoxCamera()
BaseBoundingBoxCamera ( )
◆ ~BaseBoundingBoxCamera()
~BaseBoundingBoxCamera ( )
◆ BoundingBoxData()
const std::vector< BoundingBox > & BoundingBoxData ( ) const
Buffer of bounding boxes info (label, minX, minY, maxX, maxY)
Implements BoundingBoxCamera.
References BaseBoundingBoxCamera< T >::boundingBoxes.
◆ ConnectNewBoundingBoxes()
virtual ignition::common::ConnectionPtr ConnectNewBoundingBoxes ( std::function< void(const std::vector< BoundingBox > &)>  _subscriber)
◆ DrawBoundingBox()
virtual void DrawBoundingBox ( unsigned char *  _data,
const math::Color &  _color,
const BoundingBox &  _box
) const
[in]_databuffer containing the image data
[in]_colorColor of the bounding box to be drawn
[in]_boxbounding box to be drawn
◆ SetBoundingBoxType()
void SetBoundingBoxType ( BoundingBoxType  _type)
[in]_typeBoundingBox Type (Visible / Full)
References BaseBoundingBoxCamera< T >::type.
◆ Type()
BoundingBoxType Type ( ) const
◆ boundingBoxes
std::vector<BoundingBox> boundingBoxes
Referenced by BaseBoundingBoxCamera< T >::BoundingBoxData().
◆ type
