Base implementation of an center of mass visual. More...
#include <BaseCOMVisual.hh>
virtual ~BaseCOMVisual ()
virtual ignition::math::Pose3d InertiaPose () const override
 Get the inertia pose. More...
virtual double Mass () const override
 Get the mass of the parent. More...
virtual void SetInertial (const ignition::math::Inertiald &_inertial) override
virtual void SetMass (double _mass) override
 Set the mass of the parent. More...
virtual VisualPtr SphereVisual () const override
 Get the sphere visual. More...
- Public Member Functions inherited from COMVisual
virtual ~COMVisual ()
 BaseCOMVisual ()
double SphereRadius () const
 Get the radius of the CoM sphere. More...
bool dirtyCOMVisual = false
 Flag to indicate parent properties have changed. More...
ignition::math::Pose3d inertiaPose
 Inertia pose in parent frame. More...
double mass = 1.0
 Parent mass. More...
std::string parentName = ""
 Parent visual name. More...
template<class T>
class ignition::rendering::BaseCOMVisual< T >
◆ BaseCOMVisual()
BaseCOMVisual ( )
◆ ~BaseCOMVisual()
~BaseCOMVisual ( )
◆ InertiaPose()
ignition::math::Pose3d InertiaPose ( ) const
Implements COMVisual.
void Init ( )
Reimplemented in OgreCOMVisual, and Ogre2COMVisual.
◆ Mass()
double Mass ( ) const
Parent mass
Referenced by BaseCOMVisual< Ogre2Visual >::SphereRadius().
void PreRender ( )
◆ SetInertial()
void SetInertial ( const ignition::math::Inertiald &  _inertial)
◆ SetMass()
void SetMass ( double  _mass)
[in]_massParent mass
Referenced by BaseCOMVisual< Ogre2Visual >::SetInertial().
◆ SphereRadius()
double SphereRadius ( ) const
Radius of the CoM sphere
◆ SphereVisual()
VisualPtr SphereVisual ( ) const
Pointer to the sphere visual
◆ dirtyCOMVisual
Referenced by BaseCOMVisual< Ogre2Visual >::SetMass().
◆ inertiaPose
◆ mass
double mass = 1.0
◆ parentName
Parent visual name.
