#include <Ogre2COMVisual.hh>
virtual ~Ogre2COMVisual ()
void CreateVisual ()
 Create the Light Visual in Ogre. More...
virtual VisualPtr SphereVisual () const override
 Get the sphere visual. More...
- Public Member Functions inherited from BaseCOMVisual< Ogre2Visual >
virtual ~BaseCOMVisual ()
virtual ignition::math::Pose3d InertiaPose () const override
 Get the inertia pose. More...
virtual double Mass () const override
 Get the mass of the parent. More...
virtual void SetInertial (const ignition::math::Inertiald &_inertial) override
virtual void SetMass (double _mass) override
 Set the mass of the parent. More...
- Public Member Functions inherited from COMVisual
virtual ~COMVisual ()
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual ~Ogre2Node ()
 Ogre2COMVisual ()
- Protected Member Functions inherited from BaseCOMVisual< Ogre2Visual >
 BaseCOMVisual ()
double SphereRadius () const
 Get the radius of the CoM sphere. More...
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
- Protected Attributes inherited from BaseCOMVisual< Ogre2Visual >
bool dirtyCOMVisual
 Flag to indicate parent properties have changed. More...
ignition::math::Pose3d inertiaPose
 Inertia pose in parent frame. More...
double mass
 Parent mass. More...
std::string parentName
 Parent visual name. More...
uint32_t visibilityFlags
bool wireframe
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2COMVisual()
Ogre2COMVisual ( )
◆ ~Ogre2COMVisual()
virtual ~Ogre2COMVisual ( )
◆ CreateVisual()
void CreateVisual ( )
Reimplemented from BaseVisual< Ogre2Node >.
Reimplemented from BaseCOMVisual< Ogre2Visual >.
Implements Visual.
◆ SetMaterial()
bool  _unique
Implements Visual.
◆ SetMaterialImpl()
[in]_materialOgre material.
◆ SphereVisual()
Pointer to the sphere visual
