#include <BaseGrid.hh>
| virtual | ~BaseGrid () |
| Destructor. More... | |
| virtual unsigned int | CellCount () const |
| Get the number of cells on a planar grid. More... | |
| virtual double | CellLength () const |
| Get the cell length. More... | |
| virtual void | Destroy () |
| virtual void | PreRender () |
| virtual void | SetCellCount (const unsigned int _count) |
| Set the number of cells on a planar grid. More... | |
| virtual void | SetCellLength (const double _len) |
| Set the cell length in one direction. The cells are assumed to be square. More... | |
| virtual void | SetVerticalCellCount (const unsigned int _count) |
| Set the vertical cell count of the grid. This makes the grid 3D. More... | |
| virtual unsigned int | VerticalCellCount () const |
| Get the vertical cell count. More... | |
Public Member Functions inherited from Grid | |
| virtual | ~Grid () |
| virtual | ~Geometry () |
| virtual VisualPtr | Parent () const =0 |
| BaseGrid () | |
| Constructor. More... | |
Protected Attributes | |
| unsigned int | cellCount = 10u |
| Number of cells in grid. More... | |
| double | cellLength = 1.0 |
| Length of a single cell. More... | |
| bool | gridDirty = false |
| Flag to indicate grid properties have changed. More... | |
| double | heightOffset = 0.0 |
| vertical offset of the XY plane from origin More... | |
| unsigned int | verticalCellCount = 0 |
| Number of cells in vertical direction. More... | |
template<class T>
class ignition::rendering::BaseGrid< T >
◆ BaseGrid()
protected |
◆ ~BaseGrid()
virtual |
◆ CellCount()
virtual |
◆ CellLength()
virtual |
◆ Destroy()
virtual |
◆ PreRender()
virtual |
◆ SetCellCount()
virtual |
◆ SetCellLength()
virtual |
[in] _len The cell length
Implements Grid.
◆ SetVerticalCellCount()
virtual |
[in] _count Number of cells in vertical direction.
Implements Grid.
◆ VerticalCellCount()
virtual |
◆ cellCount
protected |
Referenced by BaseGrid< OgreGeometry >::CellCount(), and BaseGrid< OgreGeometry >::SetCellCount().
◆ cellLength
protected |
Referenced by BaseGrid< OgreGeometry >::CellLength(), and BaseGrid< OgreGeometry >::SetCellLength().
◆ gridDirty
protected |
Referenced by BaseGrid< OgreGeometry >::SetCellCount(), BaseGrid< OgreGeometry >::SetCellLength(), and BaseGrid< OgreGeometry >::SetVerticalCellCount().
◆ heightOffset
protected |
◆ verticalCellCount
protected |
Referenced by BaseGrid< OgreGeometry >::SetVerticalCellCount(), and BaseGrid< OgreGeometry >::VerticalCellCount().
