Represents a grid geometry drawn along the XY plane. If vertical cell count is specified then the grid becomes 3D. More...
#include <ignition/rendering/Grid>
| virtual | ~Grid () |
| Destructor. More... | |
| virtual unsigned int | CellCount () const =0 |
| Get the number of cells on a planar grid. More... | |
| virtual double | CellLength () const =0 |
| Get the cell length. More... | |
| virtual void | SetCellCount (const unsigned int _count)=0 |
| Set the number of cells on a planar grid. More... | |
| virtual void | SetCellLength (const double _len)=0 |
| Set the cell length in one direction. The cells are assumed to be square. More... | |
| virtual void | SetVerticalCellCount (const unsigned int _count)=0 |
| Set the vertical cell count of the grid. This makes the grid 3D. More... | |
| virtual unsigned int | VerticalCellCount () const =0 |
| Get the vertical cell count. More... | |
| virtual | ~Geometry () |
| virtual VisualPtr | Parent () const =0 |
◆ ~Grid()
inlinevirtual |
References Grid::CellCount(), Grid::CellLength(), Grid::SetCellCount(), Grid::SetCellLength(), Grid::SetVerticalCellCount(), and Grid::VerticalCellCount().
◆ CellCount()
pure virtual |
- Returns
- Number of cells
Implemented in BaseGrid< T >, BaseGrid< Ogre2Geometry >, and BaseGrid< OgreGeometry >.
Referenced by Grid::~Grid().
◆ CellLength()
pure virtual |
- Returns
- The cell length
◆ SetCellCount()
pure virtual |
[in] _count The number of cells
◆ SetCellLength()
pure virtual |
[in] _len The cell length
◆ SetVerticalCellCount()
pure virtual |
[in] _count Number of cells in vertical direction.
◆ VerticalCellCount()
pure virtual |
- Returns
- The vertical cell count.
