BaseLight< T > Class Template Referenceabstract
#include <BaseLight.hh>
virtual ~BaseLight ()
virtual ~Light ()
 BaseLight ()
◆ BaseLight()
BaseLight ( )
◆ ~BaseLight()
~BaseLight ( )
◆ Reset()
◆ SetAttenuationConstant()
Implements Light.
Implemented in Ogre2Light, and OgreLight.
Referenced by BaseLight< OgreNode >::Reset().
◆ SetAttenuationLinear()
Implements Light.
◆ SetAttenuationQuadratic()
Implements Light.
◆ SetAttenuationRange()
Implements Light.
◆ SetCastShadows()
Implements Light.
◆ SetDiffuseColor() [1/2]
void SetDiffuseColor ( double  _r,
double  _g,
double  _b,
double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
Implements Light.
Referenced by BaseLight< OgreNode >::Reset(), and BaseLight< OgreNode >::SetDiffuseColor().
◆ SetDiffuseColor() [2/2]
[in]_colorNew diffuse color
Implements Light.
◆ SetSpecularColor() [1/2]
void SetSpecularColor ( double  _r,
double  _g,
double  _b,
double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
Implements Light.
Referenced by BaseLight< OgreNode >::Reset(), and BaseLight< OgreNode >::SetSpecularColor().
◆ SetSpecularColor() [2/2]
[in]_colorNew specular color
Implements Light.
