#include <OgreLight.hh>
virtual ~OgreLight ()
virtual ~BaseLight ()
virtual ~Light ()
virtual ~OgreNode ()
 OgreLight ()
 BaseLight ()
 OgreNode ()
double attenConstant
double attenLinear
double attenQuadratic
double attenRange
Ogre::Light * ogreLight
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreLight()
OgreLight ( )
◆ ~OgreLight()
virtual ~OgreLight ( )
◆ AttenuationConstant()
Implements Light.
◆ AttenuationLinear()
The attenuation linear value
Implements Light.
◆ AttenuationQuadratic()
Implements Light.
◆ AttenuationRange()
The attenuation range
Implements Light.
◆ CastShadows()
Implements Light.
Reimplemented from OgreNode.
◆ DiffuseColor()
The diffuse color
Implements Light.
◆ Intensity()
virtual double Intensity ( ) const
The light intensity
Implements Light.
◆ Light()
virtual Ogre::Light* Light ( ) const
◆ SetAttenuationConstant()
Implements BaseLight< OgreNode >.
◆ SetAttenuationLinear()
◆ SetAttenuationQuadratic()
◆ SetAttenuationRange()
◆ SetCastShadows()
◆ SetDiffuseColor()
[in]_colorNew diffuse color
◆ SetIntensity()
virtual void SetIntensity ( double  _intensity)
[in]_intensityNew light intensity
Implements Light.
◆ SetSpecularColor()
[in]_colorNew specular color
◆ SpecularColor()
The specular color
Implements Light.
◆ attenConstant
◆ attenLinear
double attenLinear
◆ attenQuadratic
◆ attenRange
double attenRange
◆ ogreLight
Ogre::Light* ogreLight
◆ ogreLightType
