Ogre2.x implementation of the arrow visual class. More...
#include <Ogre2ArrowVisual.hh>
virtual ~Ogre2ArrowVisual ()
- Public Member Functions inherited from BaseArrowVisual< Ogre2Visual >
virtual ~BaseArrowVisual ()
virtual ~ArrowVisual ()
virtual ~CompositeVisual ()
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual ~Ogre2Node ()
 Ogre2ArrowVisual ()
- Protected Member Functions inherited from BaseArrowVisual< Ogre2Visual >
 BaseArrowVisual ()
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
- Protected Attributes inherited from BaseArrowVisual< Ogre2Visual >
bool rotationVisible
 Flag to indicate whether arrow rotation is visible. More...
uint32_t visibilityFlags
bool wireframe
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2ArrowVisual()
Ogre2ArrowVisual ( )
◆ ~Ogre2ArrowVisual()
virtual ~Ogre2ArrowVisual ( )
