Ogre2DirectionalLight Class Reference
Ogre 2.x implementation of the directional light class. More...
#include <Ogre2Light.hh>
virtual ~Ogre2DirectionalLight ()
- Public Member Functions inherited from BaseDirectionalLight< Ogre2Light >
virtual ~BaseDirectionalLight ()
- Public Member Functions inherited from DirectionalLight
virtual ~DirectionalLight ()
virtual ~Light ()
virtual ~Ogre2Light ()
 Destroy the light. More...
virtual ~BaseLight ()
virtual ~Ogre2Node ()
- Protected Member Functions inherited from BaseDirectionalLight< Ogre2Light >
 Ogre2Light ()
 Initialize the light. More...
 BaseLight ()
 Ogre2Node ()
 Set the parent node. More...
double attenConstant = 1.0
double attenLinear = 0.0
double attenQuadratic = 0.0
double attenRange = 100.0
 Attenuation range. More...
 Light type. More...
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2DirectionalLight()
Ogre2DirectionalLight ( )
◆ ~Ogre2DirectionalLight()
virtual ~Ogre2DirectionalLight ( )
◆ Direction()
The direction of the light
Implements DirectionalLight.
◆ SetDirection()
[in]_dirNew direction vector
Implements BaseDirectionalLight< Ogre2Light >.
