Ogre2GaussianNoisePass Class Reference
Ogre2 Implementation of a Gaussian noise render pass. More...
#include <Ogre2GaussianNoisePass.hh>
| Ogre2GaussianNoisePass () | |
| Constructor. More... | |
| virtual | ~Ogre2GaussianNoisePass () |
| Destructor. More... | |
| void | CreateRenderPass () override |
| Create the render pass using ogre compositor. More... | |
| void | PreRender () override |
Public Member Functions inherited from BaseGaussianNoisePass< Ogre2RenderPass > | |
| virtual | ~BaseGaussianNoisePass () |
| double | Bias () const |
| Accessor for bias. More... | |
| double | Mean () const |
| Accessor for mean. More... | |
| void | SetBiasMean (double _biasMean) |
| Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation. More... | |
| void | SetBiasStdDev (double _biasStdDev) |
| Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation. More... | |
| void | SetMean (double _mean) |
| Set mean. More... | |
| void | SetStdDev (double _stdDev) |
| Set stddev. More... | |
| double | StdDev () const |
| Accessor for stddev. More... | |
Public Member Functions inherited from GaussianNoisePass | |
| virtual | ~GaussianNoisePass () |
Public Member Functions inherited from RenderPass | |
| virtual | ~RenderPass () |
Public Member Functions inherited from Ogre2RenderPass | |
| virtual | ~Ogre2RenderPass () |
| void | Destroy () override |
| std::string | OgreCompositorNodeDefinitionName () const |
| Get the ogre compositor node definition name for this render pass. More... | |
Public Member Functions inherited from BaseRenderPass< Ogre2Object > | |
| virtual | ~BaseRenderPass () |
| virtual bool | IsEnabled () const override |
| virtual void | SetEnabled (bool _enabled) override |
| virtual | ~Ogre2Object () |
| virtual | ~BaseObject () |
Protected Member Functions inherited from BaseGaussianNoisePass< Ogre2RenderPass > | |
| BaseGaussianNoisePass () | |
| void | SampleBias () |
Protected Member Functions inherited from Ogre2RenderPass | |
| Ogre2RenderPass () | |
Protected Member Functions inherited from BaseRenderPass< Ogre2Object > | |
| BaseRenderPass () | |
| Ogre2Object () | |
| BaseObject () | |
| virtual void | Init () |
| virtual void | Load () |
Protected Attributes inherited from BaseGaussianNoisePass< Ogre2RenderPass > | |
| double | bias |
| Gaussian noise bias. More... | |
| double | biasMean |
| The mean of the Gaussian distribution from which bias values are drawn. More... | |
| double | biasStdDev |
| The standard deviation of the Gaussian distribution from which bias values are drawn. More... | |
| double | mean |
| Gaussian noise mean. More... | |
| double | stdDev |
| Standard deviation of Gaussian noise. More... | |
Protected Attributes inherited from Ogre2RenderPass | |
| std::string | ogreCompositorNodeDefName |
| Name of the ogre compositor node definition. More... | |
Protected Attributes inherited from BaseRenderPass< Ogre2Object > | |
| bool | enabled |
| Flag to indicate if render pass is enabled or not. More... | |
| Ogre2ScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ Ogre2GaussianNoisePass()
◆ ~Ogre2GaussianNoisePass()
virtual |
◆ CreateRenderPass()
overridevirtual |
Reimplemented from Ogre2RenderPass.
◆ PreRender()
overridevirtual |
