#include <Ogre2GizmoVisual.hh>
virtual ~Ogre2GizmoVisual ()
- Public Member Functions inherited from BaseGizmoVisual< Ogre2Visual >
virtual ~BaseGizmoVisual ()
 Reset the gizmo visual state. More...
virtual ~GizmoVisual ()
virtual ~CompositeVisual ()
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual ~Ogre2Node ()
 Ogre2GizmoVisual ()
- Protected Member Functions inherited from BaseGizmoVisual< Ogre2Visual >
 BaseGizmoVisual ()
void CreateMaterials ()
 Create materials used by the gizmo visual. More...
void CreateRotationVisual ()
 Create gizmo visual for rotation. More...
void CreateScaleVisual ()
 Create gizmo visual for scale. More...
 Create gizmo visual for translation. More...
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
- Protected Types inherited from BaseGizmoVisual< Ogre2Visual >
enum  AxisMaterial
- Protected Attributes inherited from BaseGizmoVisual< Ogre2Visual >
VisualPtr activeVis
 Currently active visual. More...
math::Vector3d axis
 Active axis. More...
 A map of gizmo axis and their handle visuals. More...
 A map of axis enums to materials. More...
TransformMode mode
 Current gizmo mode. More...
bool modeDirty
 Flag to indicate the mode has changed. More...
 A map of gizmo axis and their visuals. More...
uint32_t visibilityFlags
bool wireframe
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2GizmoVisual()
Ogre2GizmoVisual ( )
◆ ~Ogre2GizmoVisual()
virtual ~Ogre2GizmoVisual ( )
