Ogre2.x implementation of the inertia visual class. More...
#include <Ogre2InertiaVisual.hh>
virtual ~Ogre2InertiaVisual ()
VisualPtr BoxVisual () const override
 Get the box visual. More...
void Load (const ignition::math::Pose3d &_pose, const ignition::math::Vector3d &_scale) override
- Public Member Functions inherited from BaseInertiaVisual< Ogre2Visual >
virtual ~BaseInertiaVisual ()
virtual void SetInertial (const ignition::math::Inertiald &_inertial) override
virtual ~InertiaVisual ()
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual ~Ogre2Node ()
 Set material to line geometry. More...
- Protected Member Functions inherited from BaseInertiaVisual< Ogre2Visual >
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
uint32_t visibilityFlags
bool wireframe
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2InertiaVisual()
Ogre2InertiaVisual ( )
◆ ~Ogre2InertiaVisual()
virtual ~Ogre2InertiaVisual ( )
◆ BoxVisual()
VisualPtr BoxVisual ( ) const
Get the box visual.
Pointer to the box visual
Reimplemented from BaseInertiaVisual< Ogre2Visual >.
Reimplemented from BaseVisual< Ogre2Node >.
◆ Load()
void Load ( const ignition::math::Pose3d &  _pose,
const ignition::math::Vector3d &  _scale
Implements Visual.
◆ SetMaterial()
bool  _unique
Implements Visual.
◆ SetMaterialImpl()
[in]_materialOgre material.
