Ogre2WireBox Class Reference
Ogre2 implementation of a wire box geometry. More...
#include <Ogre2WireBox.hh>
| virtual | ~Ogre2WireBox () |
| Destructor. More... | |
| virtual MaterialPtr | Material () const override |
| virtual Ogre::MovableObject * | OgreObject () const override |
| Get the ogre object representing this geometry. More... | |
| virtual void | SetMaterial (MaterialPtr _material, bool _unique) override |
Public Member Functions inherited from BaseWireBox< Ogre2Geometry > | |
| virtual | ~BaseWireBox () |
| virtual ignition::math::AxisAlignedBox | Box () const |
| Get the wireframe box. More... | |
| virtual void | Destroy () |
| virtual void | SetBox (const ignition::math::AxisAlignedBox &_box) |
| Set the axis aligned box. More... | |
Public Member Functions inherited from WireBox | |
| virtual | ~WireBox () |
| virtual | ~Geometry () |
Public Member Functions inherited from Ogre2Geometry | |
| virtual | ~Ogre2Geometry () |
| virtual VisualPtr | Parent () const override |
Public Member Functions inherited from BaseGeometry< Ogre2Object > | |
| virtual | ~Ogre2Object () |
| virtual | ~BaseObject () |
| Ogre2WireBox () | |
| Constructor. More... | |
| virtual void | SetMaterialImpl (Ogre2MaterialPtr _material) |
| Set material to wire box geometry. More... | |
Protected Member Functions inherited from BaseWireBox< Ogre2Geometry > | |
| BaseWireBox () | |
Protected Member Functions inherited from WireBox | |
| WireBox () | |
Protected Member Functions inherited from Ogre2Geometry | |
| Ogre2Geometry () | |
| virtual void | SetParent (Ogre2VisualPtr _parent) |
| Set the parent of this ogre geometry. More... | |
Protected Member Functions inherited from BaseGeometry< Ogre2Object > | |
| BaseGeometry () | |
| Ogre2Object () | |
| BaseObject () | |
| virtual void | Load () |
Protected Attributes inherited from BaseWireBox< Ogre2Geometry > | |
| ignition::math::AxisAlignedBox | box |
| bool | wireBoxDirty |
| Flag to indicate WireBox properties have changed. More... | |
Protected Attributes inherited from Ogre2Geometry | |
| Ogre2VisualPtr | parent |
| Parent visual. More... | |
| Ogre2ScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ Ogre2WireBox()
protected |
◆ ~Ogre2WireBox()
virtual |
◆ Init()
overridevirtual |
◆ Material()
overridevirtual |
◆ OgreObject()
overridevirtual |
- Returns
- Pointer to an ogre movable object
Implements Ogre2Geometry.
◆ PreRender()
overridevirtual |
Reimplemented from BaseWireBox< Ogre2Geometry >.
◆ SetMaterial()
overridevirtual |
◆ SetMaterialImpl()
protectedvirtual |
[in] _material Ogre material.
