BaseGeometry< T > Class Template Referenceabstract
#include <BaseGeometry.hh>
virtual ~BaseGeometry ()
 Clone the geometry. More...
virtual void SetMaterial (MaterialPtr _material, bool _unique=true) override=0
 BaseGeometry ()
◆ BaseGeometry()
BaseGeometry ( )
◆ ~BaseGeometry()
~BaseGeometry ( )
◆ Clone()
GeometryPtr Clone ( ) const
Clone the geometry.
The cloned geometry.
Implements Geometry.
Reimplemented in BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, BaseCapsule< Ogre2Geometry >, and BaseCapsule< OgreGeometry >.
void Destroy ( )
◆ Parent()
overridepure virtual
the parent Visual
Implemented in Ogre2Geometry, and OgreGeometry.
Referenced by BaseGeometry< OgreObject >::RemoveParent().
◆ RemoveParent()
void RemoveParent ( )
Referenced by BaseGeometry< OgreObject >::Destroy().
◆ SetMaterial() [1/2]
bool  _unique = true
Reimplemented in BaseMesh< Ogre2Geometry >, and BaseMesh< OgreGeometry >.
Referenced by BaseGeometry< OgreObject >::SetMaterial().
◆ SetMaterial() [2/2]
bool  _unique = true
Implemented in BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, Ogre2Heightmap, OgreHeightmap, Ogre2Capsule, OgreCapsule, OgreText, OgreGrid, OgreWireBox, Ogre2Grid, Ogre2WireBox, OgreMarker, and Ogre2Marker.
