OgreGaussianNoisePass Class Reference
Ogre implementation of the GaussianNoisePass class. More...
#include <OgreGaussianNoisePass.hh>
| OgreGaussianNoisePass () | |
| Constructor. More... | |
| virtual | ~OgreGaussianNoisePass () |
| Destructor. More... | |
| void | CreateRenderPass () override |
| Create the render pass using ogre compositor. More... | |
| void | Destroy () override |
| void | PreRender () override |
Public Member Functions inherited from BaseGaussianNoisePass< OgreRenderPass > | |
| virtual | ~BaseGaussianNoisePass () |
| double | Bias () const |
| Accessor for bias. More... | |
| double | Mean () const |
| Accessor for mean. More... | |
| void | SetBiasMean (double _biasMean) |
| Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation. More... | |
| void | SetBiasStdDev (double _biasStdDev) |
| Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation. More... | |
| void | SetMean (double _mean) |
| Set mean. More... | |
| void | SetStdDev (double _stdDev) |
| Set stddev. More... | |
| double | StdDev () const |
| Accessor for stddev. More... | |
Public Member Functions inherited from GaussianNoisePass | |
| virtual | ~GaussianNoisePass () |
Public Member Functions inherited from RenderPass | |
| virtual | ~RenderPass () |
Public Member Functions inherited from OgreRenderPass | |
| virtual | ~OgreRenderPass () |
| virtual void | SetCamera (Ogre::Camera *_camera) |
| Set the ogre camera that the render pass applies to. More... | |
Public Member Functions inherited from BaseRenderPass< OgreObject > | |
| virtual | ~BaseRenderPass () |
| virtual bool | IsEnabled () const override |
| virtual void | SetEnabled (bool _enabled) override |
Public Member Functions inherited from OgreObject | |
| virtual | ~OgreObject () |
| virtual | ~BaseObject () |
Public Attributes | |
| std::shared_ptr< GaussianNoiseCompositorListener > | gaussianNoiseCompositorListener |
| Gaussian noise compositor listener. More... | |
| Ogre::CompositorInstance * | gaussianNoiseInstance = nullptr |
| Gaussian noise compositor. More... | |
Protected Member Functions inherited from BaseGaussianNoisePass< OgreRenderPass > | |
| BaseGaussianNoisePass () | |
| void | SampleBias () |
Protected Member Functions inherited from OgreRenderPass | |
| OgreRenderPass () | |
Protected Member Functions inherited from BaseRenderPass< OgreObject > | |
| BaseRenderPass () | |
Protected Member Functions inherited from OgreObject | |
| OgreObject () | |
| BaseObject () | |
| virtual void | Init () |
| virtual void | Load () |
Protected Attributes inherited from BaseGaussianNoisePass< OgreRenderPass > | |
| double | bias |
| Gaussian noise bias. More... | |
| double | biasMean |
| The mean of the Gaussian distribution from which bias values are drawn. More... | |
| double | biasStdDev |
| The standard deviation of the Gaussian distribution from which bias values are drawn. More... | |
| double | mean |
| Gaussian noise mean. More... | |
| double | stdDev |
| Standard deviation of Gaussian noise. More... | |
Protected Attributes inherited from OgreRenderPass | |
| Ogre::Camera * | ogreCamera = nullptr |
| Pointer to the ogre camera. More... | |
Protected Attributes inherited from BaseRenderPass< OgreObject > | |
| bool | enabled |
| Flag to indicate if render pass is enabled or not. More... | |
Protected Attributes inherited from OgreObject | |
| OgreScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ OgreGaussianNoisePass()
◆ ~OgreGaussianNoisePass()
virtual |
◆ CreateRenderPass()
overridevirtual |
◆ Destroy()
overridevirtual |
◆ PreRender()
overridevirtual |
◆ gaussianNoiseCompositorListener
| std::shared_ptr<GaussianNoiseCompositorListener> gaussianNoiseCompositorListener |
◆ gaussianNoiseInstance
| Ogre::CompositorInstance* gaussianNoiseInstance = nullptr |
