#include <OgreSensor.hh>
virtual ~OgreSensor ()
virtual ~BaseSensor ()
 Set visibility mask. More...
 Get visibility mask. More...
 Sensor. More...
virtual ~OgreNode ()
 OgreSensor ()
 BaseSensor ()
 OgreNode ()
uint32_t visibilityMask
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreSensor()
OgreSensor ( )
◆ ~OgreSensor()
virtual ~OgreSensor ( )
