#include <OgreCamera.hh>
virtual ~OgreCamera ()
virtual math::Color BackgroundColor () const
virtual Ogre::Camera * Camera () const override
 Access the Ogre::Camera object. More...
double FarClip () const
 Get the far clip distance. More...
double NearClip () const
 Get the near clip distance. More...
virtual void SetBackgroundColor (const math::Color &_color)
void SetVFOV (double cameraVFOV) const
 Set visibility mask. More...
virtual ~BaseCamera ()
virtual ~Camera ()
 Sensor. More...
virtual ~OgreSensor ()
virtual ~BaseSensor ()
 Get visibility mask. More...
virtual ~OgreNode ()
- Public Member Functions inherited from OgreObjectInterface
virtual ~OgreObjectInterface ()
 Access to an Ogre::MovableObject. More...
 OgreCamera ()
virtual void SetSelectionBuffer ()
 BaseCamera ()
 OgreSensor ()
 BaseSensor ()
 OgreNode ()
math::Color backgroundColor
OgreRenderTargetPtr renderTexture
OgreSelectionBuffer * selectionBuffer = nullptr
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreCamera()
OgreCamera ( )
◆ ~OgreCamera()
virtual ~OgreCamera ( )
◆ AntiAliasing()
◆ AspectRatio()
The camera's aspect ratio
◆ BackgroundColor()
◆ Camera()
virtual Ogre::Camera* Camera ( ) const
Implements OgreObjectInterface.
◆ CreateRenderTexture()
◆ CreateRenderWindow()
Reimplemented from OgreNode.
◆ FarClip()
double FarClip ( ) const
Far clip distance
◆ NearClip()
double NearClip ( ) const
Near clip distance
◆ ProjectionMatrix()
Camera projection matrix
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
◆ RenderTextureGLId()
Texture Id of type GLuint.
◆ SetAntiAliasing()
◆ SetAspectRatio()
image_height /
image_width
◆ SetBackgroundColor()
◆ SetFarClipPlane()
◆ SetHFOV()
◆ SetMaterial()
◆ SetNearClipPlane()
◆ SetProjectionMatrix()
◆ SetProjectionType()
virtual void SetProjectionType ( CameraProjectionType  _type)
SetProjectionMatrix
◆ SetSelectionBuffer()
virtual void SetSelectionBuffer ( )
◆ SetVFOV()
void SetVFOV ( double  cameraVFOV) const
◆ SetVisibilityMask()
[in]_maskVisibility mask
Implements Sensor.
◆ ViewMatrix()
Camera view matrix
◆ VisualAt()
virtual VisualPtr VisualAt ( const ignition::math::Vector2i &  _mousePos)
◆ backgroundColor
◆ ogreCamera
◆ renderTexture
◆ selectionBuffer
OgreSelectionBuffer* selectionBuffer = nullptr
