| | DepthCameraSensor () |
| | constructor More...
| virtual | ~DepthCameraSensor () |
| | destructor More...
| ignition::common::ConnectionPtr | ConnectImageCallback (std::function< void(const ignition::msgs::Image &)> _callback) |
| | Set a callback to be called when image frame data is generated. More...
| virtual rendering::DepthCameraPtr | DepthCamera () |
| | Force the sensor to generate data. More...
| virtual double | FarClip () const |
| | Get image width. More...
| bool | HasConnections () const |
| | Check if there are any subscribers. More...
| | Get image height. More...
| | Initialize values in the sensor. More...
| | Load the sensor based on data from an sdf::Sensor object. More...
| | Load the sensor with SDF parameters. More...
| virtual double | NearClip () const |
| void | OnNewDepthFrame (const float *_scan, unsigned int _width, unsigned int _height, unsigned int, const std::string &) |
| | Depth data callback used to get the data from the sensor. More...
| void | OnNewRgbPointCloud (const float *_data, unsigned int _width, unsigned int _height, unsigned int, const std::string &) |
| | Point cloud data callback used to get the data from the sensor. More...
| virtual void | SetScene (ignition::rendering::ScenePtr _scene) override |
| | Set the rendering scene. More...
| | CameraSensor () |
| | constructor More...
| virtual | ~CameraSensor () |
| | destructor More...
| double | Baseline () const |
| | Get baseline for stereo cameras. More...
| std::string | InfoTopic () const |
| | Topic where camera info is published. More...
| rendering::CameraPtr | RenderingCamera () const |
| | Get pointer to rendering camera object. More...
| void | SetBaseline (double _baseline) |
| | Set baseline for stereo cameras. This is used to populate the projection matrix in the camera info message. More...
| virtual | ~RenderingSensor () |
| | destructor More...
| bool | ManualSceneUpdate () const |
| | Get whether the scene graph is updated manually. Defaults to false. More...
| void | Render () |
| | Render update. This performs the actual render operation. More...
| rendering::ScenePtr | Scene () const |
| | Get the rendering scene. More...
| void | SetManualSceneUpdate (bool _manual) |
| | Set whether to update the scene graph manually. If set to true, it is expected that rendering::Scene::PreRender is called manually before calling Render() More...
| virtual void | SetScene (rendering::ScenePtr _scene) |
| virtual | ~Sensor () |
| | destructor More...
| void | AddSequence (ignition::msgs::Header *_msg, const std::string &_seqKey="default") |
| | Add a sequence number to an ignition::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More...
| | Get flag state for enabling performance metrics publication. More...
| | FrameId. More...
| SensorId | Id () const |
| | Get the sensor's ID. More...
| bool | IsActive () const |
| | Get whether the sensor is enabled or not. More...
| | Get name. More...
| | Return the next time the sensor will generate data. More...
| | Get parent link of the sensor. More...
| ignition::math::Pose3d | Pose () const |
| | Get the current pose. More...
| | Publishes information about the performance of the sensor. This method is called by Update(). More...
| | Get the SDF used to load this sensor. More...
| | Enable or disable the sensor. Disabled sensors will not generate or publish data unless Update is called with the '_force' argument set to true. More...
| | Set flag to enable publishing performance metrics. More...
| | Set Frame ID of the sensor. More...
| | Set the parent of the sensor. More...
| void | SetPose (const ignition::math::Pose3d &_pose) |
| | Update the pose of the sensor. More...
| | Set topic where sensor data is published. More...
| | Set the update rate of the sensor. An update rate of zero means that the sensor is updated every cycle. It's zero by default. \detail Negative rates become zero. More...
| | Get topic where sensor data is published. More...
| | Update the sensor. More...
| | Get the update rate of the sensor. More...
Depth camera sensor class.
This class creates depth image from an ignition rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
