Segmentation camera sensor class. More...
#include <SegmentationCameraSensor.hh>
| SegmentationCameraSensor () | |
| constructor More... | |
| virtual | ~SegmentationCameraSensor () |
| destructor More... | |
| ignition::common::ConnectionPtr | ConnectImageCallback (std::function< void(const ignition::msgs::Image &)> _callback) |
| Set a callback to be called when image frame data is generated. More... | |
| bool | HasConnections () const |
| Check if there are any subscribers. More... | |
| Get image height. More... | |
| Get image width. More... | |
| void | OnNewSegmentationFrame (const uint8_t *_data, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format) |
| Segmentation data callback used to get the data from the sensor. More... | |
| rendering::SegmentationCameraPtr | SegmentationCamera () const |
| Get the rendering segmentation camera. More... | |
| virtual void | SetScene (ignition::rendering::ScenePtr _scene) override |
| Set the rendering scene. More... | |
Public Member Functions inherited from CameraSensor | |
| CameraSensor () | |
| virtual | ~CameraSensor () |
| double | Baseline () const |
| Get baseline for stereo cameras. More... | |
| std::string | InfoTopic () const |
| Topic where camera info is published. More... | |
| rendering::CameraPtr | RenderingCamera () const |
| Get pointer to rendering camera object. More... | |
| void | SetBaseline (double _baseline) |
| Set baseline for stereo cameras. This is used to populate the projection matrix in the camera info message. More... | |
Public Member Functions inherited from RenderingSensor | |
| virtual | ~RenderingSensor () |
| bool | ManualSceneUpdate () const |
| Get whether the scene graph is updated manually. Defaults to false. More... | |
| void | Render () |
| Render update. This performs the actual render operation. More... | |
| rendering::ScenePtr | Scene () const |
| Get the rendering scene. More... | |
| void | SetManualSceneUpdate (bool _manual) |
| Set whether to update the scene graph manually. If set to true, it is expected that rendering::Scene::PreRender is called manually before calling Render() More... | |
| virtual void | SetScene (rendering::ScenePtr _scene) |
| virtual | ~Sensor () |
| void | AddSequence (ignition::msgs::Header *_msg, const std::string &_seqKey="default") |
| Add a sequence number to an ignition::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More... | |
| FrameId. More... | |
| SensorId | Id () const |
| bool | IsActive () const |
| Get whether the sensor is enabled or not. More... | |
| Get name. More... | |
| ignition::math::Pose3d | Pose () const |
| Enable or disable the sensor. Disabled sensors will not generate or publish data unless Update is called with the '_force' argument set to true. More... | |
| void | SetPose (const ignition::math::Pose3d &_pose) |
Protected Member Functions inherited from CameraSensor | |
| bool | AdvertiseInfo () |
| Advertise camera info topic. More... | |
| bool | AdvertiseInfo (const std::string &_topic) |
| Advertise camera info topic. This version takes a string that allows one to override the camera_info topic. More... | |
| void | PopulateInfo (const sdf::Camera *_cameraSdf) |
| Populate camera info message. More... | |
| void | PublishInfo (const std::chrono::steady_clock::duration &_now) |
| Publish camera info message. More... | |
Protected Member Functions inherited from RenderingSensor | |
| RenderingSensor () | |
| void | AddSensor (rendering::SensorPtr _sensor) |
| Add a rendering::Sensor. Its render updates will be handled by this base class. More... | |
| Sensor () | |
This class creates segmentation images from an ignition rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ SegmentationCameraSensor()
constructor
◆ ~SegmentationCameraSensor()
virtual |
destructor
◆ ConnectImageCallback()
| ignition::common::ConnectionPtr ConnectImageCallback | ( | std::function< void(const ignition::msgs::Image &)> | _callback | ) |
[in] _callback This callback will be called every time the camera produces image data. The Update function will be blocked while the callbacks are executed.
- Remarks
- Do not block inside of the callback.
- Returns
- A connection pointer that must remain in scope. When the connection pointer falls out of scope, the connection is broken.
◆ HasConnections()
| bool HasConnections | ( | ) | const |
- Returns
- True if there are subscribers, false otherwise
- Todo:
- (iche033) Make this function virtual on Garden
◆ ImageHeight()
overridevirtual |
◆ ImageWidth()
overridevirtual |
◆ Init()
overridevirtual |
◆ Load() [1/2]
overridevirtual |
[in] _sdf SDF Sensor parameters.
- Returns
- true if loading was successful
◆ Load() [2/2]
overridevirtual |
- Returns
◆ OnNewSegmentationFrame()
| void OnNewSegmentationFrame | ( | const uint8_t * | _data, |
| unsigned int | _width, | ||
| unsigned int | _height, | ||
| unsigned int | _channels, | ||
| const std::string & | _format | ||
[in] _data pointer to the data from the sensor [in] _width width of the segmentation image [in] _height height of the segmentation image [in] _channels num of channels [in] _format string with the format
◆ SegmentationCamera()
| rendering::SegmentationCameraPtr SegmentationCamera | ( | ) | const |
- Returns
- Segmentation camera pointer
◆ SetScene()
overridevirtual |
◆ Update()
overridevirtual |
[in] _now The current time
- Returns
- true if the update was successful
