Ogre implementation of the DistortionPass class. More...
#include <OgreDistortionPass.hh>
 OgreDistortionPass ()
virtual ~OgreDistortionPass ()
void Destroy () override
void PreRender () override
- Public Member Functions inherited from BaseDistortionPass< OgreRenderPass >
virtual ~BaseDistortionPass ()
math::Vector2d Center () const
 Get the distortion center. More...
double K1 () const
 Get the radial distortion coefficient k1. More...
double K2 () const
 Get the radial distortion coefficient k2. More...
double K3 () const
 Get the radial distortion coefficient k3. More...
double P1 () const
 Get the tangential distortion coefficient p1. More...
double P2 () const
 Get the tangential distortion coefficient p2. More...
void SetCenter (const math::Vector2d &_center)
 Set the distortion center. More...
void SetK1 (double _k1)
 Set the radial distortion coefficient k1. More...
void SetK2 (double _k2)
 Set the radial distortion coefficient k2. More...
void SetK3 (double _k3)
 Set the radial distortion coefficient k3. More...
void SetP1 (double _p1)
 Set the tangential distortion coefficient p1. More...
void SetP2 (double _p2)
 Set the tangential distortion coefficient p2. More...
- Public Member Functions inherited from DistortionPass
 DistortionPass ()
virtual ~DistortionPass ()
virtual math::Vector2d Center () const =0
virtual double K1 () const =0
virtual double K2 () const =0
virtual double K3 () const =0
virtual double P1 () const =0
virtual double P2 () const =0
virtual ~RenderPass ()
- Public Member Functions inherited from OgreRenderPass
virtual ~OgreRenderPass ()
 Set the ogre camera that the render pass applies to. More...
virtual ~BaseRenderPass ()
static ignition::math::Vector2d Distort (const ignition::math::Vector2d &_in, const ignition::math::Vector2d &_center, double _k1, double _k2, double _k3, double _p1, double _p2, unsigned int _width, double _f)
 Apply distortion model using camera coordinates projection. More...
void CalculateAndApplyDistortionScale ()
 calculate the correct scale factor to "zoom" the render, cutting off black borders caused by distortion (only if the crop flag has been set). More...
ignition::math::Vector2d DistortionMapValueClamped (int _x, int _y) const
 get the distortion map value. More...
- Protected Member Functions inherited from BaseDistortionPass< OgreRenderPass >
- Protected Member Functions inherited from OgreRenderPass
 OgreRenderPass ()
 BaseRenderPass ()
virtual void Init ()
- Public Attributes inherited from BaseDistortionPass< OgreRenderPass >
double k1
 Radial distortion coefficient k1. More...
double k2
 Radial distortion coefficient k2. More...
double k3
 Radial distortion coefficient k3. More...
math::Vector2d lensCenter
 Lens center used for distortion. More...
double p1
 Tangential distortion coefficient p1. More...
double p2
 Tangential distortion coefficient p2. More...
- Protected Attributes inherited from OgreRenderPass
bool enabled
◆ OgreDistortionPass()
◆ ~OgreDistortionPass()
virtual ~OgreDistortionPass ( )
◆ CalculateAndApplyDistortionScale()
void CalculateAndApplyDistortionScale ( )
◆ CreateRenderPass()
void CreateRenderPass ( )
void Destroy ( )
◆ Distort()
static ignition::math::Vector2d Distort ( const ignition::math::Vector2d &  _in,
const ignition::math::Vector2d &  _center,
double  _k1,
double  _k2,
double  _k3,
double  _p1,
double  _p2,
double  _f
static
[in]_inInput uv coordinate.
[in]_centerNormalized distortion center.
[in]_k1Radial distortion coefficient k1.
[in]_k2Radial distortion coefficient k2.
[in]_k3Radial distortion coefficient k3.
[in]_p1Tangential distortion coefficient p1.
[in]_p2Tangential distortion coefficient p2.
[in]_widthWidth of the image texture in pixels.
[in]_fFocal length in pixels.
Distorted coordinate.
◆ DistortionMapValueClamped()
ignition::math::Vector2d DistortionMapValueClamped ( int  _x,
int  _y
) const
[in]_xX component of map.
[in]_yY component of map.
the distortion map value at the specified index.
void PreRender ( )
