Ogre implementation of the RenderPass class. More...
#include <OgreRenderPass.hh>
virtual ~OgreRenderPass ()
virtual void CreateRenderPass ()
void Destroy () override
 Set the ogre camera that the render pass applies to. More...
virtual ~BaseRenderPass ()
virtual ~RenderPass ()
 OgreRenderPass ()
 BaseRenderPass ()
virtual void Init ()
bool enabled
◆ OgreRenderPass()
OgreRenderPass ( )
◆ ~OgreRenderPass()
virtual ~OgreRenderPass ( )
◆ CreateRenderPass()
virtual void CreateRenderPass ( )
Reimplemented in OgreDistortionPass, and OgreGaussianNoisePass.
void Destroy ( )
◆ SetCamera()
virtual void SetCamera ( Ogre::Camera *  _camera)
[in]_cameraPointer to the ogre camera.
◆ ogreCamera
