#include <OgreMesh.hh>
virtual ~OgreMesh ()
- Public Member Functions inherited from BaseMesh< OgreGeometry >
virtual ~BaseMesh ()
 Clone the geometry. More...
 Set the mesh's mesh descriptor. More...
virtual ~Mesh ()
virtual const MeshDescriptor & Descriptor () const =0
virtual unsigned int SubMeshCount () const =0
virtual ~OgreGeometry ()
virtual ~BaseGeometry ()
 OgreMesh ()
virtual SubMeshStorePtr SubMeshes () const override
- Protected Member Functions inherited from BaseMesh< OgreGeometry >
 BaseMesh ()
virtual SubMeshStorePtr SubMeshes () const=0
 OgreGeometry ()
 BaseGeometry ()
virtual void Init ()
Ogre::Entity * ogreEntity = nullptr
OgreSubMeshStorePtr subMeshes
- Protected Attributes inherited from BaseMesh< OgreGeometry >
MeshDescriptor meshDescriptor
bool ownsMaterial
OgreVisualPtr parent
◆ OgreMesh()
OgreMesh ( )
◆ ~OgreMesh()
virtual ~OgreMesh ( )
Reimplemented from BaseMesh< OgreGeometry >.
◆ HasSkeleton()
True if the mesh has skeleton
Implements Mesh.
◆ OgreObject()
Implements OgreGeometry.
bool  _enabled,
bool  _loop = true,
float  _weight = 1.0
[in]_nameName of animation
  • Map holding:
    • Skeleton node names
◆ SetSkeletonWeights()
  • Map holding:
    • Weight the skeleton nodes
◆ SkeletonAnimationEnabled()
◆ SkeletonLocalTransforms()
  • Map holding:
Implements Mesh.
◆ SkeletonWeights()
virtual std::unordered_map<std::string, float> SkeletonWeights ( ) const
  • Map holding:
Implements Mesh.
◆ SubMeshes()
◆ UpdateSkeletonAnimation()
◆ ogreEntity
Ogre::Entity* ogreEntity = nullptr
◆ subMeshes
