OgreGeometry Class Referenceabstract
#include <OgreGeometry.hh>
| virtual | ~OgreGeometry () |
| virtual bool | HasParent () const |
| virtual Ogre::MovableObject * | OgreObject () const =0 |
| virtual VisualPtr | Parent () const |
Public Member Functions inherited from BaseGeometry< OgreObject > | |
| virtual void | SetMaterial (MaterialPtr _material, bool _unique=true) override=0 |
| virtual | ~Geometry () |
| Destructor. More... | |
Public Member Functions inherited from OgreObject | |
| virtual | ~OgreObject () |
| virtual | ~BaseObject () |
| OgreGeometry () | |
| virtual void | SetParent (OgreVisualPtr _parent) |
Protected Member Functions inherited from BaseGeometry< OgreObject > | |
| BaseGeometry () | |
Protected Member Functions inherited from OgreObject | |
| OgreObject () | |
| BaseObject () | |
| virtual void | Init () |
| virtual void | Load () |
Protected Attributes | |
| OgreVisualPtr | parent |
Protected Attributes inherited from OgreObject | |
| OgreScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ OgreGeometry()
protected |
◆ ~OgreGeometry()
virtual |
◆ HasParent()
virtual |
◆ OgreObject()
pure virtual |
Implemented in OgreMesh, OgreHeightmap, OgreText, OgreCapsule, OgreMarker, OgreWireBox, and OgreGrid.
◆ Parent()
virtual |
◆ SetParent()
protectedvirtual |
◆ parent
protected |
