Ogre 2.x implementation of a Capsule Geometry. More...
#include <Ogre2Capsule.hh>
virtual ~Ogre2Capsule ()
- Public Member Functions inherited from BaseCapsule< Ogre2Geometry >
virtual ~BaseCapsule ()
 Clone the geometry. More...
virtual double Length () const override
 Get the length of the capsule. More...
virtual double Radius () const override
 Get the radius of the capsule. More...
virtual void SetLength (double _length) override
 Set the length of the capsule. More...
virtual void SetRadius (double _radius) override
 Set the radius of the capsule. More...
- Public Member Functions inherited from Capsule
virtual ~Capsule ()
virtual ~Ogre2Geometry ()
virtual ~BaseGeometry ()
 Ogre2Capsule ()
- Protected Member Functions inherited from BaseCapsule< Ogre2Geometry >
 BaseCapsule ()
 Ogre2Geometry ()
 BaseGeometry ()
- Protected Attributes inherited from BaseCapsule< Ogre2Geometry >
bool capsuleDirty
 Flag to indicate capsule properties have changed. More...
double length
 Length of the capsule. More...
double radius
 Radius of the capsule. More...
Ogre2VisualPtr parent
 Parent visual. More...
◆ Ogre2Capsule()
Ogre2Capsule ( )
◆ ~Ogre2Capsule()
virtual ~Ogre2Capsule ( )
Reimplemented from BaseGeometry< Ogre2Object >.
Implements Geometry.
◆ OgreObject()
Implements Ogre2Geometry.
◆ SetMaterial()
bool  _unique
