Gpu Rays used to render range data into an image buffer The ogre2 implementation takes a 2 pass process to generate the final range data. 1st Pass: Creates a cubemap of range data. The cubemap is created from six cameras looking in all directions. Depending on the min/max angles specified, not all cameras need to be created. Internally in the 1st pass shaders, we reconstruct 3d viewspace pos from depth buffer data then convert them into ranges, i.e. length(pos.xyz). 2nd Pass: Samples range data from cubemap using predefined rays. The rays are generated based on the specified vertical and horizontal min/max angles and no. of samples. Each ray is a direction vector that is used to sample/lookup the range data stored in the faces of the cubemap. More...
#include <Ogre2GpuRays.hh>
virtual ~Ogre2GpuRays ()
virtual common::ConnectionPtr ConnectNewGpuRaysFrame (std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)> _subscriber) override
virtual void Copy (float *_data) override
 Copy to the specified memory direction the gpu rays data. More...
 Create dummy render texture. Needed to satisfy inheritance. More...
 All things needed to get back z buffer for gpu rays data. More...
 Pointer to the render target. More...
- Public Member Functions inherited from BaseGpuRays< Ogre2Sensor >
virtual ~BaseGpuRays ()
virtual ignition::math::Angle AngleMax () const override
 Get maximal horizontal angle value. More...
virtual ignition::math::Angle AngleMin () const override
 Get minimal horizontal angle value. More...
 Get the number of channels used to store the ray data. More...
 Get behaviour for data values outside of camera range. More...
virtual double HorizontalResolution () const override
 Get the horizontal resolution. This number is multiplied by RayCount to calculate RangeCount, which is the the number range data points. More...
 Get hoizontal range count, i.e. ray count * horz resolution. More...
 Get the ray count ratio (equivalent to aspect ratio) More...
 Get horizontal quantity of rays. More...
 Set maximal horizontal angle value. More...
 Set minimal horizontal angle value. More...
 Configure behaviour for data values outside of camera range. More...
virtual void SetHorizontalResolution (double _resolution) override
 Set the horizontal resolution. This number is multiplied by RayCount to calculate RangeCount, which is the the number range data points. More...
 Set sensor horizontal or vertical. More...
 Set horizontal quantity of rays. More...
 Sets the ray count ratio (equivalent to aspect ratio) More...
 Set maximal vertical angle value. More...
 Set minimal vertical angle value. More...
 Set vertical quantity of rays. More...
virtual void SetVerticalResolution (double resolution) override
 Set the vertical resolution. This number is multiplied by VerticalRayCount to calculate VerticalRangeCount, which is the the number vertical range data points. More...
 Set the vertical fov. More...
virtual ignition::math::Angle VerticalAngleMax () const override
 Get maximal vertical angle value. More...
virtual ignition::math::Angle VerticalAngleMin () const override
 Get minimal vertical angle value. More...
 Get vertical range count, i.e. ray count * vert resolution. More...
 Get vertical quantity of rays. More...
virtual double VerticalResolution () const override
 Get the vertical resolution. This number is multiplied by VerticalRayCount to calculate VerticalRangeCount, which is the the number vertical range data points. More...
virtual ~GpuRays ()
 Connect to a gpu rays frame signal. More...
virtual ~Camera ()
 Sensor. More...
- Public Member Functions inherited from BaseCamera< Ogre2Sensor >
virtual ~BaseCamera ()
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
 Set visibility mask. More...
 Get visibility mask. More...
virtual ~Ogre2Node ()
 Ogre2GpuRays ()
- Protected Member Functions inherited from BaseGpuRays< Ogre2Sensor >
 BaseGpuRays ()
- Protected Member Functions inherited from BaseCamera< Ogre2Sensor >
 BaseCamera ()
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node. More...
- Public Attributes inherited from BaseGpuRays< Ogre2Sensor >
bool clamping
 True if data values are clamped to camera clip distances,. More...
float dataMaxVal
 maximum value used for data outside sensor range More...
float dataMinVal
 minimum value used for data outside sensor range More...
- Protected Attributes inherited from BaseGpuRays< Ogre2Sensor >
unsigned int channels
 Number of channels used to store the data. More...
double hResolution
 Resolution of horizontal rays. More...
int hSamples
 Quantity of horizontal rays. More...
bool isHorizontal
 True if the sensor is horizontal only. More...
double maxAngle
 Horizontal maximal angle. More...
double minAngle
double rangeCountRatio
 Range count ratio. More...
double rayCountRatio
 Ray count ratio. More...
math::Angle vfov
 Vertical field-of-view. More...
double vMaxAngle
 Vertical maximal angle. More...
double vMinAngle
double vResolution
 Resolution of vertical rays. More...
int vSamples
 Quantity of verical rays. More...
- Protected Attributes inherited from BaseCamera< Ogre2Sensor >
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2GpuRays()
Ogre2GpuRays ( )
◆ ~Ogre2GpuRays()
virtual ~Ogre2GpuRays ( )
◆ ConnectNewGpuRaysFrame()
virtual common::ConnectionPtr ConnectNewGpuRaysFrame ( std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)>  _subscriber)
◆ Copy()
virtual void Copy ( float *  _data)
Reimplemented from BaseGpuRays< Ogre2Sensor >.
◆ CreateRenderTexture()
◆ Data()
virtual const float* Data ( ) const
Array of gpu rays data.
Reimplemented from Ogre2Node.
◆ PostRender()
virtual void PostRender ( )
Reimplemented from BaseCamera< Ogre2Sensor >.
◆ RenderTarget()
Implements BaseGpuRays< Ogre2Sensor >.
