Ogre2.x implementation of the mesh class. More...
#include <Ogre2Mesh.hh>
virtual ~Ogre2Mesh ()
- Public Member Functions inherited from BaseMesh< Ogre2Geometry >
virtual ~BaseMesh ()
 Clone the geometry. More...
 Set the mesh's mesh descriptor. More...
virtual ~Mesh ()
virtual ~Ogre2Geometry ()
virtual ~BaseGeometry ()
 Ogre2Mesh ()
virtual SubMeshStorePtr SubMeshes () const override
 Get a list of submeshes in this mesh. More...
- Protected Member Functions inherited from BaseMesh< Ogre2Geometry >
 BaseMesh ()
 Ogre2Geometry ()
 BaseGeometry ()
virtual void Init ()
Ogre::Item * ogreItem = nullptr
 Pointer to the ogre item object. More...
Ogre2SubMeshStorePtr subMeshes
 Store containing all the submeshes. More...
- Protected Attributes inherited from BaseMesh< Ogre2Geometry >
MeshDescriptor meshDescriptor
bool ownsMaterial
Ogre2VisualPtr parent
 Parent visual. More...
◆ Ogre2Mesh()
Ogre2Mesh ( )
◆ ~Ogre2Mesh()
virtual ~Ogre2Mesh ( )
Reimplemented from BaseMesh< Ogre2Geometry >.
◆ HasSkeleton()
True if the mesh has skeleton
◆ OgreObject()
Implements Ogre2Geometry.
bool  _enabled,
bool  _loop = true,
float  _weight = 1.0
[in]_nameName of animation
  • Map holding:
    • Skeleton node names
◆ SetSkeletonWeights()
  • Map holding:
    • Weight the skeleton nodes
◆ SkeletonAnimationEnabled()
◆ SkeletonLocalTransforms()
  • Map holding:
◆ SkeletonWeights()
virtual std::unordered_map<std::string, float> SkeletonWeights ( ) const
  • Map holding:
◆ SubMeshes()
Implements BaseMesh< Ogre2Geometry >.
◆ UpdateSkeletonAnimation()
◆ ogreItem
Ogre::Item* ogreItem = nullptr
◆ subMeshes
