SegmentationCamera Class Referenceabstract
Poseable Segmentation camera used for rendering the scene graph. This camera is designed to produce segmentation data, instead of a 2D image. More...
#include <SegmentationCamera.hh>
virtual ~SegmentationCamera ()
virtual const math::Color & BackgroundColor () const =0
 Get color for background & unlabeled items in the colored map. More...
virtual int BackgroundLabel () const =0
 Get label for background & unlabeled items in the semantic map. More...
virtual ignition::common::ConnectionPtr ConnectNewSegmentationFrame (std::function< void(const uint8_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0
 Connect to the new Segmentation image event. More...
virtual void CreateSegmentationTexture ()=0
 Create a texture which will hold the segmentation data. More...
virtual void EnableColoredMap (bool _enable)=0
 Enable Color map mode to generate colored semantics. More...
virtual bool IsColoredMap () const =0
 Check if color map mode is enabled. More...
virtual void LabelMapFromColoredBuffer (uint8_t *_labelBuffer) const =0
 Convert the colored map stored in the internal buffer to label IDs map, so users get both the colored map and the corresponding IDs map. This function must be called before the next render loop and the colored map mode must be enabeled. More...
virtual uint8_t * SegmentationData () const =0
 Get the segmentation image data. If the segmentation type is panoptic, the first two channels are the instance count, and the last channel is the label. More...
virtual void SetBackgroundColor (const math::Color &_color)=0
 Set color for background & unlabeled items in the colored map. More...
virtual void SetBackgroundLabel (int _label)=0
 Set label for background & unlabeled items in the semantic map. More...
virtual void SetSegmentationType (SegmentationType _type)=0
 Set Segmentation Type. More...
virtual SegmentationType Type () const =0
 Get Segmentation Type. More...
virtual ~Camera ()
virtual void Render ()=0
virtual void RenderTextureMetalId (void *_textureIdPtr) const =0
virtual void SetImageFormat (PixelFormat _format)=0
virtual void Update ()=0
virtual VisualPtr VisualAt (const ignition::math::Vector2i &_mousePos)=0
 Sensor. More...
 Set visibility mask. More...
 Get visibility mask. More...
ignition/rendering/SegmentationCamera.hh
◆ ~SegmentationCamera()
virtual ~SegmentationCamera ( )
inlinevirtual
◆ BackgroundColor()
virtual const math::Color& BackgroundColor ( ) const
Color of background & unlabeled items
Implemented in BaseSegmentationCamera< T >, and BaseSegmentationCamera< Ogre2Sensor >.
◆ BackgroundLabel()
virtual int BackgroundLabel ( ) const
label of background & unlabeled items
◆ ConnectNewSegmentationFrame()
virtual ignition::common::ConnectionPtr ConnectNewSegmentationFrame ( std::function< void(const uint8_t *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberSubscriber callback function. The callback function arguments are: <segmentation data, width, height, channels, format>
Implemented in Ogre2SegmentationCamera, BaseSegmentationCamera< T >, and BaseSegmentationCamera< Ogre2Sensor >.
◆ CreateSegmentationTexture()
virtual void CreateSegmentationTexture ( )
◆ EnableColoredMap()
virtual void EnableColoredMap ( bool  _enable)
[in]_enableTrue to generate colored map, False to generate label id map
◆ IsColoredMap()
virtual bool IsColoredMap ( ) const
True if colored map, False if label id map
◆ LabelMapFromColoredBuffer()
virtual void LabelMapFromColoredBuffer ( uint8_t *  _labelBuffer) const
[out]_labelBufferA buffer that is populated with the label IDs map data. This output buffer must be allocated with the same size before calling
◆ SegmentationData()
virtual uint8_t* SegmentationData ( ) const
The labels-buffer as an array of unsigned ints
◆ SetBackgroundColor()
[in]_colorColor of background & unlabeled items
◆ SetBackgroundLabel()
virtual void SetBackgroundLabel ( int  _label)
[in]_labellabel of background & unlabeled items
◆ SetSegmentationType()
virtual void SetSegmentationType ( SegmentationType  _type)
[in]_typeSegmentation Type
◆ Type()
virtual SegmentationType Type ( ) const
Segmentation Type
