Segmentation camera used to label each pixel with a label id. Supports Semantic / Panoptic Segmentation. More...
#include <Ogre2SegmentationCamera.hh>
virtual ~Ogre2SegmentationCamera ()
virtual ignition::common::ConnectionPtr ConnectNewSegmentationFrame (std::function< void(const uint8_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect to the new Segmentation image event. More...
void LabelMapFromColoredBuffer (uint8_t *_labelBuffer) const override
 Convert the colored map stored in the internal buffer to label IDs map, so users get both the colored map and the corresponding IDs map. This function must be called before the next render loop and the colored map mode must be enabeled. More...
virtual Ogre::Camera * OgreCamera () const override
 Access the Ogre::Camera object. More...
void SetBackgroundLabel (int _label) override
 Set label for background & unlabeled items in the semantic map. More...
- Public Member Functions inherited from BaseSegmentationCamera< Ogre2Sensor >
virtual ~BaseSegmentationCamera ()
virtual const math::Color & BackgroundColor () const override
 Get color for background & unlabeled items in the colored map. More...
virtual int BackgroundLabel () const override
 Get label for background & unlabeled items in the semantic map. More...
virtual void EnableColoredMap (bool _enable) override
 Enable Color map mode to generate colored semantics. More...
virtual bool IsColoredMap () const override
 Check if color map mode is enabled. More...
virtual uint8_t * SegmentationData () const override
 Get the segmentation image data. If the segmentation type is panoptic, the first two channels are the instance count, and the last channel is the label. More...
virtual void SetBackgroundColor (const math::Color &_color) override
 Set color for background & unlabeled items in the colored map. More...
virtual void SetSegmentationType (SegmentationType _type) override
 Set Segmentation Type. More...
virtual SegmentationType Type () const override
 Get Segmentation Type. More...
- Public Member Functions inherited from SegmentationCamera
virtual ~SegmentationCamera ()
virtual ~Camera ()
 Sensor. More...
- Public Member Functions inherited from BaseCamera< Ogre2Sensor >
virtual ~BaseCamera ()
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
 Set visibility mask. More...
 Get visibility mask. More...
virtual ~Ogre2Node ()
- Public Member Functions inherited from Ogre2ObjectInterface
virtual ~Ogre2ObjectInterface ()
 Access to an Ogre::MovableObject. More...
void CreateCamera ()
 Create the camera. More...
 Create render texture. More...
virtual void CreateSegmentationTexture () override
 Create a texture which will hold the segmentation data. More...
- Protected Member Functions inherited from BaseSegmentationCamera< Ogre2Sensor >
- Protected Member Functions inherited from BaseCamera< Ogre2Sensor >
 BaseCamera ()
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node. More...
- Protected Attributes inherited from BaseSegmentationCamera< Ogre2Sensor >
math::Color backgroundColor
 The color of objects that are considered background (i.e., objects that have no label) More...
int backgroundLabel
 The label of background objects. More...
bool isColoredMap
 Whether a colored map is being generated (true) or label ID map is being generated (false) More...
uint8_t * segmentationData
 The buffer that contains segmentation data. More...
SegmentationType type
 The segmentation type. More...
- Protected Attributes inherited from BaseCamera< Ogre2Sensor >
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2SegmentationCamera()
Ogre2SegmentationCamera ( )
◆ ~Ogre2SegmentationCamera()
virtual ~Ogre2SegmentationCamera ( )
◆ ConnectNewSegmentationFrame()
virtual ignition::common::ConnectionPtr ConnectNewSegmentationFrame ( std::function< void(const uint8_t *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberSubscriber callback function. The callback function arguments are: <segmentation data, width, height, channels, format>
Reimplemented from BaseSegmentationCamera< Ogre2Sensor >.
◆ CreateCamera()
void CreateCamera ( )
Create the camera.
◆ CreateRenderTexture()
◆ CreateSegmentationTexture()
virtual void CreateSegmentationTexture ( )
Implements BaseSegmentationCamera< Ogre2Sensor >.
Reimplemented from Ogre2Node.
◆ LabelMapFromColoredBuffer()
void LabelMapFromColoredBuffer ( uint8_t *  _labelBuffer) const
[out]_labelBufferA buffer that is populated with the label IDs map data. This output buffer must be allocated with the same size before calling
◆ OgreCamera()
virtual Ogre::Camera* OgreCamera ( ) const
Implements Ogre2ObjectInterface.
◆ PostRender()
virtual void PostRender ( )
Reimplemented from BaseCamera< Ogre2Sensor >.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
Pointer to the render target
Implements BaseCamera< Ogre2Sensor >.
◆ SetBackgroundLabel()
void SetBackgroundLabel ( int  _label)
[in]_labellabel of background & unlabeled items
◆ ogreCamera
