#include <OgreGrid.hh>
virtual ~OgreGrid ()
virtual void Init ()
virtual MaterialPtr Material () const
virtual Ogre::MovableObject * OgreObject () const
virtual void PreRender ()
virtual void SetMaterial (MaterialPtr _material, bool _unique)
- Public Member Functions inherited from BaseGrid< OgreGeometry >
virtual ~BaseGrid ()
virtual unsigned int CellCount () const
 Get the number of cells on a planar grid. More...
virtual double CellLength () const
 Get the cell length. More...
virtual void Destroy ()
virtual void SetCellCount (const unsigned int _count)
 Set the number of cells on a planar grid. More...
virtual void SetCellLength (const double _len)
 Set the cell length in one direction. The cells are assumed to be square. More...
virtual void SetVerticalCellCount (const unsigned int _count)
 Set the vertical cell count of the grid. This makes the grid 3D. More...
virtual unsigned int VerticalCellCount () const
 Get the vertical cell count. More...
virtual ~Grid ()
virtual unsigned int CellCount () const =0
virtual double CellLength () const =0
virtual unsigned int VerticalCellCount () const =0
 Clone the geometry. More...
virtual ~OgreGeometry ()
virtual ~BaseGeometry ()
 OgreGrid ()
- Protected Member Functions inherited from BaseGrid< OgreGeometry >
 BaseGrid ()
 OgreGeometry ()
 BaseGeometry ()
- Protected Attributes inherited from BaseGrid< OgreGeometry >
unsigned int cellCount
 Number of cells in grid. More...
double cellLength
 Length of a single cell. More...
bool gridDirty
 Flag to indicate grid properties have changed. More...
double heightOffset
 vertical offset of the XY plane from origin More...
unsigned int verticalCellCount
 Number of cells in vertical direction. More...
OgreVisualPtr parent
◆ OgreGrid()
OgreGrid ( )
◆ ~OgreGrid()
virtual ~OgreGrid ( )
Implements Geometry.
◆ OgreObject()
Implements OgreGeometry.
Reimplemented from BaseGrid< OgreGeometry >.
◆ SetMaterial()
bool  _unique
◆ SetMaterialImpl()
[in]_materialOgre material.
