#include <OgreMarker.hh>
virtual ~OgreMarker ()
virtual void AddPoint (const ignition::math::Vector3d &_pt, const ignition::math::Color &_color) override
 Destroy function. More...
 PreRender function. More...
virtual void SetPoint (unsigned int _index, const ignition::math::Vector3d &_value) override
- Public Member Functions inherited from BaseMarker< OgreGeometry >
virtual ~BaseMarker ()
virtual void AddPoint (double _x, double _y, double _z, const ignition::math::Color &_color) override
virtual ~Marker ()
 Clone the geometry. More...
virtual ~OgreGeometry ()
virtual ~BaseGeometry ()
 OgreMarker ()
- Protected Member Functions inherited from BaseMarker< OgreGeometry >
 BaseMarker ()
 Marker ()
 OgreGeometry ()
 BaseGeometry ()
- Protected Attributes inherited from BaseMarker< OgreGeometry >
int32_t layer
bool markerDirty
MarkerType markerType
 Marker type. More...
double size
 Marker size. More...
OgreVisualPtr parent
◆ OgreMarker()
OgreMarker ( )
◆ ~OgreMarker()
virtual ~OgreMarker ( )
◆ AddPoint()
virtual void AddPoint ( const ignition::math::Vector3d &  _pt,
Reimplemented from BaseMarker< OgreGeometry >.
◆ ClearPoints()
virtual void ClearPoints ( )
Destroy function.
Implements Geometry.
◆ OgreObject()
Implements OgreGeometry.
PreRender function.
◆ SetMaterial()
bool  _unique
◆ SetPoint()
◆ SetType()
◆ Type()
The render type of the marker
Implements Marker.
