#include <DepthCamera.hh>
Public Types | |
| virtual | ~DepthCamera () |
| Destructor. More... | |
| virtual ignition::common::ConnectionPtr | ConnectNewDepthFrame (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0 |
| Connect to the new depth image signal. More... | |
| virtual ignition::common::ConnectionPtr | ConnectNewRgbPointCloud (std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0 |
| Connect to the new rgb point cloud signal. More... | |
| virtual void | CreateDepthTexture ()=0 |
| Create a texture which will hold the depth data. More... | |
| virtual const float * | DepthData () const =0 |
| All things needed to get back z buffer for depth data. More... | |
| virtual | ~Camera () |
| Renders a new frame and writes the results to the given image. This is a convenience function for single-camera scenes. It wraps the pre-render, render, post-render, and get-image calls into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| virtual void | RenderTextureMetalId (void *_textureIdPtr) const =0 |
| Get the Metal texture id associated with the render texture used by this camera. A valid Id is obtained only if the underlying render engine is Metal based. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease. More... | |
| Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render, render, and post-render into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| virtual VisualPtr | VisualAt (const ignition::math::Vector2i &_mousePos)=0 |
| virtual | ~Sensor () |
| Sensor. More... | |
| virtual | ~Node () |
Member Typedef Documentation
◆ NewFrameListener
| typedef std::function<void(const void*, unsigned int, unsigned int, unsigned int, const std::string&)> NewFrameListener |
◆ ~DepthCamera()
inlinevirtual |
References DepthCamera::ConnectNewDepthFrame(), DepthCamera::ConnectNewRgbPointCloud(), DepthCamera::CreateDepthTexture(), and DepthCamera::DepthData().
◆ ConnectNewDepthFrame()
pure virtual |
[in] _subscriber Subscriber callback function
- Returns
Implemented in Ogre2DepthCamera, OgreDepthCamera, BaseDepthCamera< T >, BaseDepthCamera< Ogre2Sensor >, and BaseDepthCamera< OgreSensor >.
Referenced by DepthCamera::~DepthCamera().
◆ ConnectNewRgbPointCloud()
pure virtual |
[in] _subscriber Subscriber callback function The arguments of the callback function are: _pointCloud Point cloud data. Each point is represented by four 32 bit floating point values [X, Y, Z, RGBA]. The last field can be decoded into 4 unsigned 8 bit color values: uint32_t *rgba = reinterpret_cast<uint32_t *>(&_rgba) r = static_cast<uint8_t>(*rgba >> 24 & 0xFF); g = static_cast<uint8_t>(*rgba >> 16 & 0xFF); b = static_cast<uint8_t>(*rgba >> 8 & 0xFF); a = static_cast<uint8_t>(*rgba >> 0 & 0xFF); _width Point cloud image width _height Point cloud image height _depth Point cloud image depth _format Point cloud image format
- Returns
◆ CreateDepthTexture()
pure virtual |
Implemented in OgreDepthCamera, Ogre2DepthCamera, BaseDepthCamera< T >, BaseDepthCamera< Ogre2Sensor >, and BaseDepthCamera< OgreSensor >.
◆ DepthData()
pure virtual |
- Returns
- The z-buffer as a float array
