Depth camera used to render depth data into an image buffer. More...
#include <Ogre2DepthCamera.hh>
virtual ~Ogre2DepthCamera ()
void AddRenderPass (const RenderPassPtr &_pass) override
virtual ignition::common::ConnectionPtr ConnectNewDepthFrame (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect a to the new depth image signal. More...
virtual ignition::common::ConnectionPtr ConnectNewRgbPointCloud (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect a to the new rgb point cloud signal. More...
virtual void CreateDepthTexture () override
 Create a texture which will hold the depth data. More...
 Create dummy render texture. Needed to satisfy inheritance. More...
virtual const float * DepthData () const override
 All things needed to get back z buffer for depth data. More...
double FarClipPlane () const override
 Get the far clip distance. More...
 Initialize the camera. More...
double NearClipPlane () const override
 Get the near clip distance. More...
virtual Ogre::Camera * OgreCamera () const override
 Access the Ogre::Camera object. More...
 Render the camera. More...
 Set the far clip distance. More...
 Set the near clip distance. More...
void SetShadowsDirty () override
- Public Member Functions inherited from BaseDepthCamera< Ogre2Sensor >
virtual ~BaseDepthCamera ()
virtual ignition::common::ConnectionPtr ConnectNewRGBPointCloud (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)
- Public Member Functions inherited from DepthCamera
virtual ~DepthCamera ()
virtual ignition::common::ConnectionPtr ConnectNewRgbPointCloud (std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0
 Connect to the new rgb point cloud signal. More...
virtual ~Camera ()
 Sensor. More...
- Public Member Functions inherited from BaseCamera< Ogre2Sensor >
virtual ~BaseCamera ()
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
 Set visibility mask. More...
 Get visibility mask. More...
virtual ~Ogre2Node ()
- Public Member Functions inherited from Ogre2ObjectInterface
virtual ~Ogre2ObjectInterface ()
 Access to an Ogre::MovableObject. More...
 Ogre2DepthCamera ()
void CreateCamera ()
 Create the camera. More...
- Protected Member Functions inherited from BaseDepthCamera< Ogre2Sensor >
 BaseDepthCamera ()
- Protected Member Functions inherited from BaseCamera< Ogre2Sensor >
 BaseCamera ()
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node. More...
Static Protected Member Functions
static double LimitFOV (const double _fov)
 Limit field of view taking care of using a valid value for an OGRE camera. More...
Ogre::Camera * ogreCamera
- Protected Attributes inherited from BaseCamera< Ogre2Sensor >
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
Ogre2NodeStorePtr children
Ogre2NodePtr parent
- Public Types inherited from DepthCamera
◆ Ogre2DepthCamera()
Ogre2DepthCamera ( )
◆ ~Ogre2DepthCamera()
virtual ~Ogre2DepthCamera ( )
◆ AddRenderPass()
Reimplemented from BaseCamera< Ogre2Sensor >.
◆ ConnectNewDepthFrame()
virtual ignition::common::ConnectionPtr ConnectNewDepthFrame ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
Reimplemented from BaseDepthCamera< Ogre2Sensor >.
◆ ConnectNewRgbPointCloud()
virtual ignition::common::ConnectionPtr ConnectNewRgbPointCloud ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
◆ CreateCamera()
void CreateCamera ( )
Create the camera.
◆ CreateDepthTexture()
virtual void CreateDepthTexture ( )
Set up 1st pass material, texture, and compositor
◆ CreateRenderTexture()
◆ DepthData()
virtual const float* DepthData ( ) const
The z-buffer as a float array
Reimplemented from Ogre2Node.
◆ FarClipPlane()
double FarClipPlane ( ) const
Far clip distance. A value of zero is returned if the ogre camera has not been created.
◆ LimitFOV()
static double LimitFOV ( const double  _fov)
staticprotected
[in]_fovexpected field of view
valid field of view
◆ NearClipPlane()
Near clip distance. A value of zero is returned if the ogre camera has not been created.
◆ OgreCamera()
virtual Ogre::Camera* OgreCamera ( ) const
Implements Ogre2ObjectInterface.
◆ PostRender()
virtual void PostRender ( )
Render the camera.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
Pointer to the render target
Implements BaseCamera< Ogre2Sensor >.
◆ SetFarClipPlane()
[in]_farfar clip distance
◆ SetNearClipPlane()
[in]_nearNear clip distance
◆ SetShadowsDirty()
void SetShadowsDirty ( )
◆ ogreCamera
Ogre::Camera* ogreCamera
