Depth camera used to render depth data into an image buffer. More...
#include <rendering/ogre/OgreDepthCamera.hh>
virtual ~OgreDepthCamera ()
virtual Ogre::Camera * Camera () const override
 Access the Ogre::Camera object. More...
virtual ignition::common::ConnectionPtr ConnectNewDepthFrame (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect a to the new depth image signal. More...
virtual ignition::common::ConnectionPtr ConnectNewRgbPointCloud (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect a to the new rgb point cloud signal. More...
virtual void CreateDepthTexture () override
 Create a texture which will hold the depth data. More...
virtual const float * DepthData () const override
 All things needed to get back z buffer for depth data. More...
double FarClipPlane () const override
 Get the far clip distance. More...
 Initialize the camera. More...
double NearClipPlane () const override
 Get the near clip distance. More...
 Render the camera. More...
 Set the far clip distance. More...
 Set the near clip distance. More...
- Public Member Functions inherited from BaseDepthCamera< OgreSensor >
virtual ~BaseDepthCamera ()
virtual ignition::common::ConnectionPtr ConnectNewRGBPointCloud (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)
- Public Member Functions inherited from DepthCamera
virtual ~DepthCamera ()
virtual ignition::common::ConnectionPtr ConnectNewRgbPointCloud (std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0
 Connect to the new rgb point cloud signal. More...
virtual ~Camera ()
 Sensor. More...
virtual ~BaseCamera ()
virtual ~OgreSensor ()
virtual ~BaseSensor ()
 Set visibility mask. More...
 Get visibility mask. More...
virtual ~OgreNode ()
- Public Member Functions inherited from OgreObjectInterface
virtual ~OgreObjectInterface ()
 Access to an Ogre::MovableObject. More...
 OgreDepthCamera ()
void CreateCamera ()
 Create the camera. More...
void UpdateRenderTarget (OgreRenderTexturePtr _target, Ogre::Material *_material, const std::string &_matName)
 Update a render target. More...
- Protected Member Functions inherited from BaseDepthCamera< OgreSensor >
 BaseDepthCamera ()
 BaseCamera ()
 OgreSensor ()
 BaseSensor ()
 OgreNode ()
Static Protected Member Functions
static double LimitFOV (const double _fov)
 Limit field of view taking care of using a valid value for an OGRE camera. More...
bool captureData = false
OgreRenderTexturePtr depthTexture
 Pointer to the depth texture. More...
Ogre::Viewport * depthViewport = nullptr
 Pointer to the depth viewport. More...
bool newData = false
 Communicates that a frams was rendered. More...
Ogre::Camera * ogreCamera
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
OgreNodeStorePtr children
OgreNodePtr parent
- Public Types inherited from DepthCamera
◆ OgreDepthCamera()
OgreDepthCamera ( )
◆ ~OgreDepthCamera()
virtual ~OgreDepthCamera ( )
◆ Camera()
virtual Ogre::Camera* Camera ( ) const
Implements OgreObjectInterface.
◆ ConnectNewDepthFrame()
virtual ignition::common::ConnectionPtr ConnectNewDepthFrame ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
Reimplemented from BaseDepthCamera< OgreSensor >.
◆ ConnectNewRgbPointCloud()
virtual ignition::common::ConnectionPtr ConnectNewRgbPointCloud ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
◆ CreateCamera()
void CreateCamera ( )
Create the camera.
◆ CreateDepthTexture()
virtual void CreateDepthTexture ( )
◆ DepthData()
virtual const float* DepthData ( ) const
The z-buffer as a float array
Reimplemented from OgreNode.
◆ FarClipPlane()
double FarClipPlane ( ) const
Far clip distance. A value of zero is returned if the ogre camera has not been created.
◆ LimitFOV()
static double LimitFOV ( const double  _fov)
staticprotected
[in]_fovexpected field of view
valid field of view
◆ NearClipPlane()
Near clip distance. A value of zero is returned if the ogre camera has not been created.
◆ PostRender()
virtual void PostRender ( )
Render the camera.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
Pointer to the render target
Implements BaseCamera< OgreSensor >.
◆ SetFarClipPlane()
[in]_farfar clip distance
◆ SetNearClipPlane()
[in]_nearNear clip distance
◆ UpdateRenderTarget()
void UpdateRenderTarget ( OgreRenderTexturePtr  _target,
Ogre::Material *  _material,
const std::string &  _matName
[in]_targetRender target to update
[in]_materialMaterial to use
[in]_matNameMaterial name
◆ captureData
◆ depthTexture
◆ depthViewport
Ogre::Viewport* depthViewport = nullptr
◆ newData
◆ ogreCamera
Ogre::Camera* ogreCamera
