#include <OgreLight.hh>
virtual ~OgrePointLight ()
- Public Member Functions inherited from BasePointLight< OgreLight >
virtual ~BasePointLight ()
- Public Member Functions inherited from PointLight
virtual ~PointLight ()
virtual ~Light ()
virtual ~OgreLight ()
virtual ~BaseLight ()
virtual ~OgreNode ()
 OgrePointLight ()
- Protected Member Functions inherited from BasePointLight< OgreLight >
 BasePointLight ()
 OgreLight ()
 BaseLight ()
 OgreNode ()
double attenConstant
double attenLinear
double attenQuadratic
double attenRange
Ogre::Light * ogreLight
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgrePointLight()
OgrePointLight ( )
◆ ~OgrePointLight()
virtual ~OgrePointLight ( )
